Planars & Exotics ESL's, planars, and alternative technologies
Mundorf AMT 27d
Mundorf AMT 27d
Old 11th February 2015, 11:16 AM   #11
phazer99 is offline phazer99  Sweden
Originally Posted by solhaga View Post
But wouldn't it then be less vertical dispersion with two AMT on top of each other and not greater?
Not for high frequencies. A bit oversimplified the dispersion pattern of a finite line source goes from spherish to cylinderish as the wavelength becomes smaller and smaller relative to the length of the source. So if you place two line sources on top of each other you are basically building a longer line source and higher dispersion cylinder. The two sources should be placed as close to each other to avoid uneven dispersion. Also ideally the length of the line source should be much greater than the wave length of the sound it reproduces otherwise the dispersion pattern will look more like that of a point source.
Old 11th February 2015, 11:33 AM   #12
solhaga is offline solhaga  Sweden
Maybe it is a matter of wording.
To me a taller line array means a smaller dispersion, from Wiki:
"The taller the stack is, the narrower the vertical dispersion will be and the higher the sensitivity will be on-axis"
Old 11th February 2015, 11:43 AM   #13
annerholm is offline annerholm  Sweden
Maybe I'm wrong here, but in this case isn't it about the actual dispersion at the ends of the driver? If I understood phaser99 right, a shorter AMT driver will start to act as a line source higher up in frequence than a taller driver. So, when stacked, even if it acts together it will still have this dispersion at the ends according to the/it's driver size?
I mean, for ex. compared between a 240mm tall driver and 2x120m.
Or if I put it like this: Should 2xAMT25d be better than one AMT27d in terms of vertical dispersion?
Old 11th February 2015, 11:53 AM   #14
I would say that one 27d is better as it can be hard to get two 25ds close enough in order to consider them as one line source. Another down side with two 25ds apart from each other is that combing will occur.
Old 11th February 2015, 11:54 AM   #15
Yes, maybe I use incorrect wording. The dispersion off-axis of a specific frequency will be less the longer the line source, but the actual on-axis area with more even frequency response will be larger. I think a focused vertical dispersion about 0.5 - 1 m tall in the listening position would be good as it eliminates most floor/ceiling reflections while still being tall enough to cover all common listening positions.
Old 11th February 2015, 11:59 AM   #16
Great! Then we have the same view.
I think your last sentence is the main reason for domestic use of line arrays.
Old 11th February 2015, 12:09 PM   #17
For greater vertical dispersion (and less distortion) you can always stack two of them vertically.
Ok, I think I got it wrong. You probably meant just compared to one driver on axis. So even if a shorter driver has better vertical disperion (due to it's size), that will increase when stacked? So a line source of a certain length - regardless of if it's one or many drivers - has theoretically always the same vertical dispersion?
Old 11th February 2015, 12:09 PM   #18
Keith Taylor is offline Keith Taylor  Australia
Mundorf AMT 27d
Indeed it would. Anders, we are talking about basic acoustic principles. The kind you would encounter in an acoustics text book.
For every transducer there are physical dimensions to the radiating surfaces, which, in the case of the AMT are unequal between horizontal and vertical.
The other important dimension is the "acoustic size", meaning the physical dimension in relation to the wavelength we are considering. Some texts designate this relationship ka. ka can vary from fractional values through unity (where the wavelength and radiator dimension are equal) to double digits. A source with dimensions much smaller than the wavelength is described as "acoustically small" All woofers would fit this description. A source with dimensions much bigger than the wavelength is "acoustically large".
The AMT we are discussing is acoustically small in the horizontal plane but
large over much of its range in the vertical plane. Acoustically small = broad directivity. Acoustically large = narrow directivity. Making a few assumptions such as pistonic motion; it does not matter who made the speaker driver, its directivity characteristics have been largely defined by the dimensions.
Keith
Old 11th February 2015, 12:22 PM   #19
I agree with that one 27D should be better than two 25D in a line source application. I think a (questionable?) rule of thumb is a driver distance of at most half the wavelength in a line array and at 15 kHz this would mean about 1 cm which might be hard to achieve.
Regarding vertical dispersion of the 27D, it looks acceptable at +/- 3 degrees off-axis which would give you a listening window about 0.5 m tall at 3 m listening distance. Sounds ok to me.
Old 11th February 2015, 12:27 PM   #20
Thanks Keith, good explanations, cleared up things up here in my brain;-)
I just made an estimation considering that the AMT25d has almost the same SPL on axis as at 5 degrees. It's diaphragm seems to be about 90mm tall. Then, at a 3m listening distance it would have a good response that is about 600mm tall.
If you compare this to the AMT27d that has really bad SPL at 5 degrees, and has a diaphragm that is about 200mm tall. Which would make for a good response that is 200mm tall (or if optimistic at 2,5 degress about 450mm tall..).
So the smaller 25d (just one) would give a taller vertical response than the bigger 27d if I'm correct.
But then the 25d is harder to xo and acoustically small...
(phaser99: didn't see your post before posting this)
Mundorf AMT 27dHide this!Advertise here!
New AMT drivers from Mundorf Tape Echo Planars & Exotics 7 7th September 2013 07:33 AM
Mundorf New AMT Line Telstar Planars & Exotics 17 13th September 2011 08:52 PM
Can new Mundorf AMT be run dipole? Zodiac Multi-Way 0 29th September 2010 04:25 AM
What happened to the Mundorf AMT? cuibono Planars & Exotics 2 28th April 2010 02:01 AM
Mundorf AMT 2440 for sale chengtaw Swap Meet 1 21st February 2008 03:08 PM
