Proper material for replacing dust covers on ESL-63's? Proper material for replacing dust covers on ESL-63's? - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 12th November 2014, 07:16 PM   #1
240z4u is offline 240z4u  United States
Send a message via AIM to 240z4u
Default Proper material for replacing dust covers on ESL-63's?
Well I am a new owner of a pair of Quad ESL-63's
I was aware that a dust cover was missing when I bought the speakers. I'd like to replace it. The frame and all that jazz is there I am just a bit stymied when it comes to choosing a film. I've read that 3m window film is actually too thick.
What's the correct film to use? I found some PET on mcmaster carr of the correct? thickness at .0005" but am unsure if I can heat this stuff to shrink it the last bit required for a tight fit. The other dust cover seems kind of floppy to me too so it may need to be replaced as well.
Thanks for the help guys.
Evan
BTW, here's the McMaster link McMaster-Carr
Yeah... it seemed like a good idea at the time.
Old 12th November 2014, 09:59 PM   #2
golfnut is offline golfnut  New Zealand
golfnut's Avatar
I believe the dustcover film is 2 um Mylar
Rod
“Nothing is more practical than a good theory.”
– Ludwig Boltzmann
Old 12th November 2014, 10:05 PM   #3
Thanks Rod.
Old 13th November 2014, 05:44 AM   #4
lcsaszar is offline lcsaszar  Hungary
2 um is impossible to handle. It must be 6 um IMHO. There is another thread in this topic, see:
http://www.diyaudio.com/forums/plana...-3-micron.html
Old 13th November 2014, 01:13 PM   #5
Thanks for the link. I don't know how I missed that.
Old 14th November 2014, 10:22 PM   #6
WrineX is offline WrineX  Netherlands
WrineX's Avatar
3 Um
for sure. its lightly stretched , 3 Um is easy to do just strecth it without wrinkles on glas and glue or use double sides tape, if you need you can use a heat gun to get rid of the last wrinkles.
its resoance must be way below the panels res, wich is easy its getting it high that is hard so no problems there !
Old 14th November 2014, 11:03 PM   #7
Thank you!
Old 15th November 2014, 01:36 AM   #8
CharlieM is offline CharlieM  United States
CharlieM's Avatar
This thread is a bit confusing... are you looking for material to replace the diaphragm or the dust cover?
Old 15th November 2014, 01:38 AM   #9
Dust cover.
Old 15th November 2014, 12:06 PM   #10
CharlieM's Avatar
OK....I'm still confused. And I'm not familiar with ESL 63 construction. Are we talking about the permanent grill covering or a removable dust cover that's only used to cover the speakers when not playing?
(Dayton Wright gas filled ESL's encased the panel in a gas-tight bag but you wouldn't want to do that otherwise, I figure)
Proper material for replacing dust covers on ESL-63's?Hide this!Advertise here!
Dust cap covers... 10" and 4" betaman72 Parts 0 14th March 2014 03:02 PM
DigitalDeckCovers Custom Dust Covers for all your gear! ddc Vendor's Bazaar 0 19th October 2013 04:25 AM
Gradient Sw-63, Quad-63 Esl Williams Audio Swap Meet 5 29th March 2009 03:16 PM
replacing a Pro-ject 1.2 dust cover stephen Bishop Analogue Source 6 8th November 2006 10:32 PM
Copyright ©1999-2017 diyAudio
