Planars & Exotics ESL's, planars, and alternative technologies
Yet another DIY Planar Bass
Old 25th July 2014, 09:02 AM   #41
solhaga is offline solhaga  Sweden
Default Back to the drawing board
Have tried to fit the VC in the gap.
Ideally, the gap is 4 mm and the VC 1,5 mm, so there a little more than 1 mm margin on each side of the VC.
So for sure, I can make it fit, but there will be no margins in any direction.
And the reality isn't ideal along the 500 mm long gap.
The VC is 4 mm in height so Xmax is modest too, only 3 mm ((10 - 4)/2).
Old 25th July 2014, 09:12 AM   #42
Default Don't panic!
New magnet assembly coming up:
The iron in the gap has changed from 3x10 mm to 2x15 mm.
This gives 2 mm of additional space in the gap (6 mm - 1,5 mm) and a longer Xmax (15 - 4 / 2 = 5,5 mm).
This comes at a cost of a lower field:
But only 35 % lower (new gap to the right):
Click the image to open in full size. Click the image to open in full size.
I have also simulated 1,5x15 mm, that is a gap of 7 mm:
It would work as well and is perhaps preferable, but that thin rods are hard to come by; you'll have to make them out of 1,5 mm steel sheets and then hard to get straight.
Old 2nd August 2014, 10:02 PM   #43
Paul W is offline Paul W  United States
Paul W's Avatar
Try substituting small Neo magnets for the small pieces of iron in the FEMM sims.
Paul
Old 3rd August 2014, 09:26 AM   #44
I´ve been doing simulations on such circuits in the past and even if the field is stronger they are more suitable for ribbons as they have less linear excursion.
They are also harder to build.
Do you mean something like this:
Old 3rd August 2014, 10:40 AM   #45
båndsei is offline båndsei  Denmark
Maybe like this:
[IMG]data/1954/medium/amt_planar_drawing.JPG[/img][/IMG]
[IMG]Click the image to open in full size.[/IMG]
[IMG]img]http://origin.dastatic.com/forums/gallery/data/1954/medium/amt_planar_field_.JPG[/img][/IMG]
It is 5x10mm neo ,5mm gap.
But maybe you dont need a fieldstrength that strong.
It is a very long field compared to a "normal" speaker.2" voicecoil app.160mm.
Bernt
Old 3rd August 2014, 10:46 AM   #46
a.wayne is offline a.wayne  United States
Sin Bin
No image Bandsei .....!
Old 3rd August 2014, 10:51 AM   #47
Just started using DIY Audio gallery for images.
Bernt
Old 3rd August 2014, 12:03 PM   #48
WrineX is offline WrineX  Netherlands
WrineX's Avatar
nice one bandsei, some linear excursion there. verry even.
Old 3rd August 2014, 12:42 PM   #49
Great idea to saturation at the bottom in order to limit the field in the gap.
Old 3rd August 2014, 01:42 PM   #50
WrineX's Avatar
Agt would you want to limit it ? If it's even then it is ok or am I missing something ? If you want lower field strength you can increase gap or use cheaper magnets ?
Yet another DIY Planar BassHide this!Advertise here!
diy planar... again ionomolo Planars & Exotics 4 29th January 2015 01:34 PM
noob question, planar speakers vs ESL on bass hello im sean Planars & Exotics 10 15th May 2012 01:23 PM
Audionec planar bass driver el`Ol Planars & Exotics 13 22nd June 2010 05:42 AM
Planar bass wave to take care of room modes ?? JinMTVT Subwoofers 12 4th October 2007 06:15 PM
