Planars & Exotics ESL's, planars, and alternative technologies
Tube Amp for ESL
Tube Amp for ESL
Old 6th March 2002, 10:07 PM   #11
Mohan Varkey is offline Mohan Varkey  Australia
Paul, thanks for the links.
There are three basic OTL topologies that I am aware of:
Single Ended OTL: Good old days when high impedance speaker loads were common. This is my preferred option. However this is not practical with the majority of speakers available today.
Futterman: Where the cathode of the driver tube is connected to the output. Simple and very effective concept.
Circlotron: Two current paths.
Modern topologies are all variations of the two latter types where feedback is a necessity. Hence my reservations. The only exception is Steve Bench’s Inverted Tube Amp that requires a large number of tubes.
Returning to the main discussion topic, perhaps Dave could enlighten us a bit more on his concepts of an input transformer for ESLs. What should the secondary current be at peak output?
Dave, are you planning to construct a single panel OTL or multiple full range panels? Just curious!
Mohan
Old 7th March 2002, 09:20 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tube Amp for ESL
The ESLs are just concepts at the moment -- and not mine (i'll just supply the venue). The idea is to take an amp that can swing significant voltage -- say 300 or 500 volts and then step it up 1:10 to get the 3-5k volts needed for the ESLs. Beyond that i can't tell you much more -- i sat over coffee as Bill & Menno talked this over, and i understood about 10% of what they said -- these two guys know a lot about transformers.
The panels will be mostly full-range (150 Hz & up) of easily manufactured size and stacked to produce a large line array (20-30 ft tall). As frequency goes up the driven panel will get narrower.
There are many things that need to fall into place before we can start prototyping.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th March 2002, 11:54 AM   #13
Thanks Dave.
Mohan
Tube Amp for ESLHide this!Advertise here!
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FS tube tuner, Active filter kit, tube amp, amp3 Josephjcole Swap Meet 9 20th July 2007 04:05 PM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
tube driving the same tube - whats the collective word? zobsky Tubes / Valves 3 13th June 2005 06:47 AM
