but 2 % is almost nothing, i got tensiled mylar C i believe from dijkstra, this rather expands then shrink. if i have a wrinkele and heat threat it the whole thing sacks in, and will be worse then before using the heat gun. i think it stated a 2 percent shrink as well
It will shrink, but not that much. If you have stretched this mylar very tight mechanically, additional heat will lower the tension (and divide it in some extend).
By the way I am still working on a strongly curved esl. In the past I made one consisting of several flat elements but I found it to work only moderate (audible dips, non-uniform dispersion)
