Planars & Exotics ESL's, planars, and alternative technologies
Driving ESL headphones - some questions
Old 2nd March 2014, 07:46 PM   #1
playOvation is offline playOvation  Germany
playOvation's Avatar
Default Driving ESL headphones - some questions
I am pretty new in ESL designs and recently played around with some DIY-transducers.
My very first experiments were driven by the simple "step up transformer"-method
that soon blew my test amp because I wanted some more bass out of that (too small) transformer
Nonetheless, now I have got some spare time and so I want to improve my design by building a direct drive system.
But there's a question that I can't find a simple answer to it:
is there any difference in driving the ESL's stators rather than the diaphragm?
Most of the designs I have seen by now bias the diaphragm and drive the stators phase-inverted.
But to me both driving options seem equal Plus, driving the diaphragm rather than the stators only needs one amplifier.
So, can anybody tell me the difference or (dis-)advantages?
Old 3rd March 2014, 02:05 AM   #2
geraldfryjr is offline geraldfryjr  United States
Hi there!
It has been shown that by using a very high resistance coating on the diaphgarm and driving the stators lowers the THD especially for the lower frequency's.
This is called constant charge mode.
There have been many discussions on the ups and downs of using a direct drive amplifiers in these threads.
The main and biggest issue involved is the use and safety of such high voltages as they are in the order of 10 to 20 times more than what is required to drive a smaller sized headphone unit.
All else aside, I am all for designing a DD system for ESL's as I have been pursuing this goal for the better part of the last 10 years or so.
But, DO BE VERY AWARE of the level of voltages involved, and, ESPECIALLY the HIGHER CURRENTS at those increased voltages that is Required!!
The biggest issue is finding output devices with good characteristics at audio frequency's using such high voltages.
There are some out there but it takes time to sort through them all, as I have created a few lists in these thread already.
The second issue of concern is the amount of driving voltages needed to drive such a system, as it can take as much as 10KV peak to drive a system to its fullest potential.
But a workable system can be realised using amp running on 2Kv to 3Kv power supply as well using a push pull or bridged(BTL) using a Class A SE amplifier on each stator.
Creating a amplifier that uses a bipolar power supply at these type of voltages would be quite an undertaking, but not impossible to do.
More on that later.
This will allow a voltage swing across the stator that is approximately double the supply's voltage at 4Kv to 6Kv peak.
This much voltage is probably ample for a large panel ESL to SPL's that would put you out of the room.
It would work also for smaller sized one as well, but at a lower SPL and but still be plenty loud enough to listen to, as it would have a lesser amount of surface area.
I have been specializing in the building of smaller desktop panels and I have gotten them to get as high +105db and more at 1 meter using such voltages.
It takes using a very high bias voltage on the diaphragm at about 7Kv to 10Kv or so to do it.
Using such a high bias voltage increases the sensitivity +6b for every doubling of the Bias voltage.
This greatly reduces the required drive current and power demand from the amplifier and only took about 3KV to 6Kv peak on the stators to realize such SPL's at 100db and above.
Stator coating materials become a big issue in the design of the panel at this point to keep it from arcing and burning up!!
Yes, I have burned a few and fire now becomes the main issue on the extreme side of things.
I do believe that such a system can be realized as long as all factors are taken into consideration.
It takes less power to drive an ESL at the lower frequency's than it does to drive them at the highest frequency's.
Besides the action of Dipole Cancellation working against you, ESL's can produce bass providing that they have enough displacement as well.
But in most cases it is the cost and size of the step-up transformer design is the limiting factor on low frequency performance.
This has been discussed time and time again.
I think that the best of both worlds could be combined to produce a decent full range system with using a D-D amp for the lower frequency's and a transformer for the higher frequency's.
This is a concept that I have been thinking about in more recent years.
Much like what has already been done with commercial interfaces that use the technique of having two step-up transformers but only eliminating one with a D-D amp.
Using the D-D amp for only the lowest frequency's greatly reduces the power requirement of the D-D amplifier itself, While increasing the ESL's performance for the lower frequency's without the need of some costly and heavy iron.
Just a few thoughts FWIW.
jer
P.S. Sorry for going a little OT as your questions were more geared for headphone ESL drivers, Therefore the drive requirements are not as extreme but the concept is the same for the most part.
I have posted some examples of ESL amp designs in these threads suitable for small drivers as well in the Headphones forum.
I just get very excited as I am very interested in such things!!
Old 3rd March 2014, 04:49 AM   #3
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by playOvation View Post
But to me both driving options seem equal Plus, driving the diaphragm rather than the stators only needs one amplifier...can anybody tell me the difference or (dis-)advantages?
In order to drive an ESL using the diaphragm, the coating on the diaphragm must be highly conductive and driven by a low source impedance. If it isn't, the high frequencies will be rolled off. So, the question becomes, what are the disadvantages of a highly conductive diaphragm?
1) Distortion. ESLs made with highly conductive diaphragms have much more distortion than those made with highly resistive diaphragms. These two methods of driving ESLs are often called "Constant Voltage" and "Constant Charge" respectively.
More information on the difference between these methods here:
http://www.diyaudio.com/forums/plana...ml#post3589946
2) Stability. ESLs made with highly conductive diaphragms have a non-linear drive mechanism that increases the force on the diaphragm the closer it gets to either stator. This acts like a non-linear stiffness term that often results in the diaphragm collapsing and sticking to one of the stators.
Plots of the nonlinear behavior here:
http://www.diyaudio.com/forums/plana...ml#post1886659
3) Arcing. ESLs made with highly conductive diaphragms have the potential for high-current arcing between the diaphragm and stators. Burning small holes in the diaphragm from the little lightning bolts is the best case. In more spectacular arcing events, the diaphragm and/or stators can catch on fire. Not exactly what I want to have next to my ears.
Old 3rd March 2014, 05:02 AM   #4
jcx is offline jcx  United States
commercial current production ESL headphones from Stax, Koss are constant charge, balanced Stator drive
the balanced drive is another advantage that gives 2x the Vswing for a given supply/output device Vrating
head-fi.org and Head-Case.org both have diy sections with ESL headphone and amp projects
Old 3rd March 2014, 06:23 AM   #5
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
I've been making many ES headphones and amplifiers in the past few years. If you are interested in making your own, here is the link
Wachara C.
Old 3rd March 2014, 07:44 AM   #6
Calvin is offline Calvin  Germany
Calvin's Avatar
At first glance this is correct.At least in theory both options will work.
At closer look there are distinct differences, most of which have been listed in the threads above.
It might help to understand that the working principle of a symmetric constant charge (cc) ESL differs fundamentally from the constant voltage (cv), driven membrane ESL.
The differneces regard the treatment and functioning of the membrane.
With the cc ESL the two stators span up a signal dependent electrical filed. The membrane is the support for a charge, on which the field can at upon.
One could say that the field grabs the charge and tosses it around.
The forces rise with increased field strength and amount of charge.
As the field can be made very homogenous and the mass of the charged membrane doesn´t count at audio frequencies, he electrostatic drive is perfectly linear.
The membrane is coated wth a high-ohmic compound to keep a charge on the membrane and stationary over the membrane area.
Due to this high impedance a possible arc over takes up much less energy, that may not get hot enough to melt a hole into the membrane, let alone that it could burn the whole.
The cv ESL is basically a sandwich of two single-ended ESLs where the stators are charged up with opposite polarities.
From its single ended nature follows, that the membrane must be seen as a moving stator.
It takes up an active part of the drive system.
As the signal voltage is applied to the membrane its coating must be low ohmic.
This means that signal dependent charging currents flow.
The high voltage stresses the coating and membrane contact already, but while the currents are negligibly small and quite constant with a cc ESL they are much larger and varying with an cv ESL.
This has been a source of unreliabilty and breakdown (it took Final off of the market).
In case of a arc over, the spark can devolp much more energy and heat, thereby melting larger holes in the membrane or burn it down completely.
Beeing of single ended nature the driving forces are not linear, but vary quadratically.
Sandwiched together this non-linearity cancels to a first degree, but still remains higher than with a cc ESL.
jauu
Calvin
Old 3rd March 2014, 05:47 PM   #7
thanks for all your answers, I see there's a lot for me to learn about
Originally Posted by geraldfryjr
But, DO BE VERY AWARE of the level of voltages involved (...)
I surely will Though one of my research topics in the past were Tesla transformers, this one here has got my brain between it and so I will at least triple check everything
@bolserst:
Great! Exactly what I wanted to know
I missed that one Of course, that's a HUGE advantage.
@chinsettawong:
Just searched around a bit for your posts and... I'm more than very impressed of your designs There are some details I'll have to copy when building my "final design"
That's something I surely want to avoid. Not just for the reason someone (me...) being hurt, it's more like "everything I build catches fire" And I'll have to build it again.
Hopefully not this time...
Now I'm going back to do some more research and maybe in some time I'll present my result
Best regards.
Driving ESL headphones - some questionsHide this!Advertise here!
what amplifier for driving esl hironimo Planars & Exotics 32 3rd March 2015 05:12 PM
DAC driving headphones directly from I/V opamp? maxw Digital Line Level 17 2nd January 2014 01:56 AM
Audiosector DAC driving headphones? mattjuk81 Audio Sector 0 15th August 2012 05:21 PM
class t driving esl's snivit Class D 4 4th August 2005 04:20 AM
AD8392 driving headphones astouffer Solid State 0 7th October 2004 04:52 AM
Copyright ©1999-2017 diyAudio
