Planars & Exotics ESL's, planars, and alternative technologies
Martin Logan Aerius i HT Board Transformer Kaputt !?
Old 7th October 2013, 08:57 PM   #21
alaneglinton is offline alaneglinton
you can see difference in terminals....
faulty board has 4 /5 connections, replacement only 2
Old 8th October 2013, 10:56 PM   #22
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by alaneglinton View Post
The transformer has exactly the same readings on both 103 and 102 boards so don't think that's my problem any more that's why I switched the whole board.
When you say "same readings", what do you mean? are you measuring voltages at the secondary terminals of the transformer when the supply is powered up that match those of the 102 board and your other 103 board? If so, I guess I don't understand what you meant in your initial post when you said you had narrowed down the problem to an open winding in the transformer.
Taking a step back...had you tried swapping the power supplies(or panels) between your working and non-working speaker to verify that it is the power supply and not the panel that is the problem?
Old 9th October 2013, 09:15 PM   #23
By same readings I meant resistance
Turned out my 'open winding' on the 103 was also open on the 102 board I know works so I obviously didn't measure across the right terminals in the first place.
I have already swapped 103 PCB's across speakers and the fault moved with the board so I am 100% sure the board is the issue.
Looks like I can go with the connections as I planned given feedback from forum and ML - will try tomorrow and report back
Old 10th October 2013, 02:42 AM   #24
bolserst's Avatar
Good to hear.
Replacement panels are more costly than HV supplies and more difficult to DIY repair.
Let me know if you are interested in trying to repair your 103 HV supply.
I can send you some troubleshooting steps to narrow down where the fault lies.
Oh, I forgot to comment on the strategy you mentioned in post#19 for connecting your 3 ground wires to the 102 PCB.
I think your proposed connections should work just fine.
Old 12th October 2013, 03:20 PM   #25
Default All good !
Quick Update...
New board fitted and wired as per posts here and everything now works superbly well !
Very happy and thanks to everyone for the great advice...
Old 6th January 2014, 01:10 AM   #26
FPN is offline FPN
Default Aerius HV transformer.
Guys,
I also have problem with Aerius HV transformer on HT Board on both speaker.
I try to source the similar type but can't find here, some electrician say this is a customize model by ML.
Please let me know if anyone able to help me get the HV transformer (new/second hand) and willing to send to Indonesia.
You can PM me.
Thanks.
FPN.
Martin Logan Aerius i HT Board Transformer Kaputt !?Hide this!Advertise here!
Martin Logan Aerius i panel removal servasol Planars & Exotics 13 7th June 2016 10:41 PM
Recoating Martin Logan Aerius Panel FPN Planars & Exotics 40 27th January 2014 06:19 AM
Martin Logan Aerius fuse Sandor Planars & Exotics 1 29th June 2013 09:09 AM
Help Martin Logan janbb Planars & Exotics 6 4th November 2012 06:53 PM
Repair of Martin Logan Aerius i jorn Planars & Exotics 3 4th April 2010 03:50 PM
