Beyma TPL Rear Chamber Experiments Beyma TPL Rear Chamber Experiments - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th June 2013, 08:37 PM   #1
vinylnvalves is offline vinylnvalves  United Kingdom
Default Beyma TPL Rear Chamber Experiments
I have noticed a number of people are running Beyma TPL's " open baffle" and with custom rear chambers. I have therefore experimented to see what the effects are of removing the rear compression chamber off my Beyma TPL's.
Bit of background - i am running mine in a custom "le cleach" expansion horn which are significantly larger than the standard OEM horns. The only noticeable effect was smoother roll off below <1000Hz. I am currently running them crossed @ 1200Hz and am looking at lifting this as they can sound harse. (I suppose secretly i was hoping the rear chamber experiment may sort out the harshness)
Attached below is a trace of the 3 configurations - all measurements taken from listening position 2.5m away. http://i1227.photobucket.com/albums/...psd6bc79ca.png
The rear chamber i made had non-parallel sides in a 3:2:4 ratio with approx volume of 5 ltrs. I stuffed around 50% of this with BAF.
You can see the OEM chamber has the flattest response, i don't understand why my oversize chamber is so bad. Do i need to put back the felt on the back of the driver? Any suggestions on ways to improve the FR. I think they sound better without the chamber, but the loss of imagery outways this, so some type of chamber needs to go back on them
Old 15th June 2013, 08:59 AM   #2
Audiodidakt is offline Audiodidakt  Norway
Very interesting, pictures of the horn? And some data on size, cut-off frequency etc?
(Please &#128515
Br
Gisle
Old 19th June 2013, 11:23 AM   #3
attached is a link to another thread which details some of my trials
Beyma TPL 150 - horn trials
Old 20th June 2013, 07:28 AM   #4
StigErik is offline StigErik  Norway
StigErik's Avatar
The 9kHz peak is typical when the rear damping felt pad is removed. This must to EQ'ed.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Beyma TPL Rear Chamber ExperimentsHide this!Advertise here!
WTB: Beyma TPL-150 Hrmmf Swap Meet 1 9th April 2013 10:53 AM
WTB: Beyma TPL-150 or TPL-150H NYCOne Swap Meet 0 9th July 2012 04:09 PM
TPL-150H vs WL3 (Beyma) ? Bigun Multi-Way 1 25th June 2012 07:38 AM
WTD: Beyma TPL 150H waterl00 Swap Meet 0 12th November 2011 09:50 AM
Beyma TPL-150H - what EQ anyone using? bvan Planars & Exotics 0 3rd November 2011 07:10 AM
Copyright ©1999-2017 diyAudio
