Planars & Exotics ESL's, planars, and alternative technologies
Stacked Quad ESL 57
Stacked Quad ESL 57
Old 31st May 2013, 02:14 PM   #11
a.wayne is offline a.wayne  United States
Sin Bin
Proper stands and adjustments are super critical , very much so on triple and quad panel setups . Todate the double sounds best to me and the triple sounds most majestic in a large room , recreating the power and size of a symphony with ease, you do need a big , big room to get far enuff for them to work.....
I want to believe a curved array is best ...
Old 31st May 2013, 11:09 PM   #12
AVWERK is offline AVWERK  United States
AVWERK's Avatar
To realize a double stack and come at least close to a single pair in accurate impulse response would make the upper pair be angled down and forward of the lower pair as if drawing an arc vertically and equal distance from the listener.
I remember a drawing from John Koval I vaguely remember many moons ago, showing this configuration while at his house listening to some apogees.
This ugly setup would preserve what a pair does better than 4 this side of more bass and loudness capability
Any other straight up stack will compromise in some way what a single pair does so wonderfully
Tearing them apart and reconfiguring their arangement as some have done seems appropiate as long as time alignment is considered
IMO
You will gain something and lose something depending on your priorites
David
Old 31st May 2013, 11:44 PM   #13
owenhamburg is offline owenhamburg  Germany
riple and quad panel setups . Todate the double sounds best to me and the triple sounds most majestic in a large room , recreating the power and size of a symphony with ease, you do need a big , big room to get far enuff for them to work.....[/QUOTE]
Very interesting to hear, my room would just not support that scale of speaker. Lucky you to have the space.
Maybe I am thinking about this wrong but I don't understand how a curved electrostatic driver can work well, and a array of electrostatic speakers arranged in a curve seems unnecessarily complex, when designs like the ESL 63 seem so much more elegant in solving sound dispersion.
Just my 2 cents.
Old 2nd June 2013, 04:45 PM   #14
Tubenstein is offline Tubenstein
I have conversation with my friend recently, and he prefers wired the Quad ESL 57 all the way in "parallel", and this is what he told me: "......there is a benefit to going parallel. Speaker wires in series will play off each other's load, and since they will never be acoustically loaded the same, their outputs will vary between them...."
To have the zero impedance autoformer between the power amplifier and the BIG Quad ESL system to cure 2 problems:
1) The low impedance by paralleling 3 to 4 pairs of ESL 57
2) The Autoformer can completely eliminate the high capacitive issue.
Autoformers offered by ZeroImpedance- Improve your speaker sound quality with the use of an autoformer.
For the best performance with such a big stacked Quads system, it's better to have a Supertweeter centrally in each gap. This will require three pairs of Supertweeters and a gap of at least 32mm between the Quads.
IMG_1541.jpg Photo by jloveys | Photobucket
Finally the stand for 4 pairs stacking should be "angle adjustable" for individual ESL 57.
Old 2nd June 2013, 04:53 PM   #15
Default Gradient SW-D
Yes, have discussed with my friend and he has thought of the Gradient SW-D in stacking! Each SW-D has 4 x 12" drivers in dipole configuration and specially made for Quad ESL 57. It will have 8 x 12" drivers per channel by stacking the SW-D, and it nominal impedance is 4 ohm.
But concern about the physical stability since it's over 9 feet tall and might have a problem for one SW-D sitting on the others.....also crossover point is another issue. Unlike the 63/2805, the ESL 57 doesn't like any subwoofer and woofer of any kind with cut off at 100Hz or above based on people has tried b4. But hard to say what will happen with some digital bass eq or acoustics correctional system.
Originally Posted by owenhamburg View Post
I have never had the possibility to try this, but I agree with your concerns that the treble panel will be very directional. The reason is for the maximum volume producible, and the lowest frequency producible.
My expectation is that since the high frequencies are so directional that if the two panels are misaligned you might even have two sweet spots. Careful positioning will be essential. If I was doing this I would suggest that the stand would be critical, and it should be adjustable, to reduce the issues you and I suspect would occur.
If I could bring my self to modify such a classic as the ESL 57 (Sort of like modifying a 1960's classic car with a modern engine). I might even adjust the drive electronics, to make the system a three way (With a DIY electrostatic tweeter, and call the high frequency panels on the ESL 57 as mid ranges). But if I was going this way I personally would be more tempted to start with ESL 63 panels and drive electronics, and stack the bass panels either side of a ESL 63, either making a taller or wider speaker than an ESL 63.
I suspect sealed or dipole bass under an ESL 57 with an active crossover is both a cheaper and more pragmatic solution to maximum volume and limited bass performance of an ESL57.
Honestly the ESL 57 is very good as designed, and already a very large and potentially dominating speaker in most European sized rooms. But you already need to be a music professional or Hifi obsessive to want an electrostatic speaker, and the accompanied experience, we are not mass market in this forum, and this "Planars & Exotics" topic.
Old 2nd June 2013, 10:57 PM   #16
Sin Bin
Correct you want adjustability of each panel to shape the curve towards listening position. The gradient subwoofer is not worth the effort , poor sonics and not enuff output IMO , a double and or triple stack has plenty weight , those subs wont make a dent ....
Old 2nd June 2013, 11:52 PM   #17
geraldfryjr is offline geraldfryjr  United States
Those Auto transformers are awful expensive !!!
Not to mention $600 for a pair of cherry wood boxes with some run of the mill gold plated binding posts!!
You can probably accomplish the same thing using a pair of toroidal power transformers (such as the antek's) with two 120v winding's each and wire the 120V winding's in a 2:1 step-Down configuration.
I did a test of running one of my two-way speakers straight through 1:1 using the two 120V winding's and found the sound to be the same as without using the transformer.
I only detected a very very slight muddiness on the very extreme low end below about 60Hz or so, But nothing that ruined the quality of the overall sound.
I suspect that this was caused by the amplifier having less control and dampening effect on the woofer due to the interfacing of the transformer or that that I just needed more core area for such a low frequency extension.
Everything else was great!
This test was done to test the ability of the transformers core for audio use, particularly for ESL's before I had actually tried it as a step-up for my ESL.
FWIW
jer
P.S. You could do this using either, one or two cores.
Using two cores may give you better low frequency performance.
Old 3rd June 2013, 11:02 AM   #18
Dear Tubenstein,
Since you seem to like Quad II amplifiers and ESL 57's, and the cost of a pair of Autoformers by ZeroImpedance cost about the same as a pair good condition refurbished Quad II amplifiers, why not just spend the few pounds extra and buy a Quad II amplifier per speaker, the resale value of Quad II's is higher should you change your mind later, the sound will be more predictably a scaled up version of what you have with one amp, and I suspect the sound will be better than parallel or autoformer based matching.
Best of luck what ever you do. Owen
Old 3rd June 2013, 06:12 PM   #19
Sorry! This is my friend's system not mine. I just helping him to gather more opinions for consideration :-)
Normally big speaker systems are very hard to control and setup.
Dear Tubenstein,
Old 17th June 2013, 07:03 AM   #20
303 is a class B amplifier if my memory serve me proper?
I agree the Quad 303 is a great match for the ESL 57 and has a real good retro look that just works with the ESL 57, and has been destined for and to avoid overloading the ESL 57 and causing damage. The Quad 303 is noisy by modern standards ( you probably wont need to worry about the little hiss that you only hear with your ear near the speaker)
Using multiple Quad 303's I would use line transformers between the Quad 303 and your preamp to isolate the earths for simplicity. Because the Quad 303 regulates the earth rather than the HT voltage you cant connect the earths of the Quad 303 together or you will fry the regulation on the amplifiers. I have done this so many times before I worked this out I feel stupid.
The Quad 303 is a great partner for the ESL 57, and is nice that at factory spec levels they cant destroy the ESL 57 with overloads I believe.
Best of luck.
Owen
Stacked Quad ESL 57Hide this!Advertise here!
Stacked pair of Quad ESL 57 arend-jan Planars & Exotics 61 4th January 2014 07:48 AM
Quad ESL 57 panels? Simon T Planars & Exotics 5 8th February 2012 06:09 AM
Quad ESL 57 connection discurio Planars & Exotics 3 20th April 2011 02:25 AM
QuAD ESL 57 Question dude007 Planars & Exotics 30 5th March 2010 07:45 PM
Quad ESL-57 (pair) TimA Swap Meet 2 14th November 2005 11:34 AM
Copyright ©1999-2017 diyAudio
