Planars & Exotics ESL's, planars, and alternative technologies
Another segmented ESL
Old 29th April 2013, 04:31 AM   #11
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Nice work! Congratulations!
Old 29th April 2013, 05:00 AM   #12
Calvin is offline Calvin  Germany
Calvin's Avatar
I think I remember a 80s or 90s patent (probabely even earlier as it seems that everything regarding ESLs had been invented already in the first 5minutes since the first thought on that matter was written down) the concept of a high impedance and varying high impedance stator was described.
Using todays printing technology one might think of printing a high-ohmic ink onto a punched, routed or cast insulator. An idea I'm rolling in my head for a couple of years now is a stator manufactured completely from clear transparent materials. Transparent inks are offered in various resistance ranges. So all one needs to design the 'invisible' ESL is there
jauu
Calvin
Ps. just in case someone thinks he could patent this idea like Sanders got an patent on an PCB stator in 2005 that Beveridge had done decades earlier already ..... No! Its open source now
Pps. Stephen, could never get Your script running on my pc.
Old 29th April 2013, 07:51 AM   #13
golfnut is offline golfnut  New Zealand
golfnut's Avatar
esltransformer: the nominal capacitance of the panels is about 620 pF. The lacquer coating was put on afterwards, so finished capacitance is greater, maybe 700 pF. The capacitance of the smallest segment at the beginning of the transmission line is about 20 pF – the larger segments at the end of the transmission line are about 3 times that.
Bolserst: Thanks for posting the links.
Calvin: Yes, there is a patent, I can’t remember whose, that describes a conductive stator, effectively with the transmission line built in. From what I recall, the author did not envisage a line source. I have looked into the possibility and there are conductive plastic sheets available that would do the job, including acrylic. The problem is that they are intended for antistatic applications and the uniformity of resistance is not that good – may be good enough though.
Old 29th April 2013, 04:33 PM   #14
bolserst is offline bolserst  United States
bolserst's Avatar
Hmmm, I'm not sure why you would be having problems with the Line source Excel spreadsheet.
The are no unusual requirements to run it.
Feel free to contact me via email or PM to sort it out.
I know you had problems with the near/intermediate/field field Excel spreadsheet because it required the Analysis ToolPak be loaded and you did not have the installation CD.
http://www.diyaudio.com/forums/plana...ml#post2916242
link to the near/intermediate/field field Excel spreadsheet:
http://www.diyaudio.com/forums/plana...ml#post2913884
For those curious about golfnut's "sausage-like" transformers, here is a pictorial representation of the stacked toroid concept that Alexberg posted in another thread:
http://www.diyaudio.com/forums/plana...ml#post3372969
Old 29th April 2013, 08:27 PM   #15
geraldfryjr is offline geraldfryjr  United States
Thanks Calvin!!!
Didn't get no sleep again brainstorming about those Clear ESL's again!!!!!
May be some Licron can be used for a resistive stator design.
jer
Old 30th April 2013, 05:18 AM   #16
Calvin's Avatar
I rather thought of pure clear acrylics with a printed-on layer of conductive transparent ink and sealed with an transparent insulative coating/laquer. The membrane could be transparent as well as the membrane coating. The stators could be routed from acrylic sheets and heat treated after to get the matted surfaces clear again and the sharp edges rounded, or it may even be better cast into a mould, thereby allowing to include spacers and stiffening ribs at the same. The conductive ink may be printed on with standard inkjet printer technology. There are several different formulations over a certain ohmic range. Lowohmic inks may be used as replacement for cabling and copper charge ring. A special transparent laquer, commonly used for insulating and sealing PCBs may be used as insulative layer also. It may be possible to replace the insulative coating by a second cast of acrylics, thereby sealing the conductive areas completely within the stator structure.
If not cast into the stator structure, 3M's clear transparent tapes may be used as spacers. The mounting frame may of course be made from standard acrylic material again. So all is there ... the idea, the materials an the technologies. The only thing I'm still missing ...... and that's the point You Gerald my friend, come into play, are transparent toroids
jauu
Calvin
Old 30th April 2013, 07:44 AM   #17
golfnut's Avatar
Hi Calvin
I wouldn't use a router to cut the acrylic, laser cutting is much faster and leaves a rounded edge. Screen printed inks sounds good though - how would you make the connections to the resistors?
Old 30th April 2013, 10:56 AM   #18
Oh my, Calvin!!
Now my head is a spinnin'!!!!
You know my method would be to completely eliminate the toroid's all together with a direct drive system!!!
Using some sort of transparent Vaccum tube or maybe a larger planar transparent semiconductor FET !!!!
jer
Old 30th April 2013, 11:08 AM   #19
Golfnut, The connections can be quite easily made!
Since the material is basically painted on you can just paint right over a few connecting foil strips where ever a connection is needed as I have done here,
http://www.diyaudio.com/forums/plana...ml#post2142822
Or you can use a simple pressure contact method as well.
I used both techniques in that particular design to connect to the diaphragm and can be used in the stator construction as well.
jer
Old 1st May 2013, 02:40 AM   #20
alexberg is offline alexberg
alexberg's Avatar
Originally Posted by golfnut View Post
Hi Calvin
I would not use laser on acrylic: it creates extreme stress at the edges and one have to anneal the whole thing and still you'll get the whole bunch of whisker kinda cracks. Proper router bit would yield any kind of edge you like.
Another segmented ESLHide this!Advertise here!
Segmented Wire Stator ESL simulator (esl_seg_ui) bolserst Planars & Exotics 92 10th December 2016 11:13 PM
ER Audio ESL III Kit, and ESL questions in general wixy Planars & Exotics 27 29th July 2014 11:14 PM
New design for segmented ribbon tweeters Spatz Planars & Exotics 8 5th June 2013 09:55 PM
segmented panels Lucius Planars & Exotics 10 5th July 2006 07:18 AM
angles for segmented ESL? Few Planars & Exotics 21 25th February 2005 03:30 PM
