Planars & Exotics ESL's, planars, and alternative technologies
Rebuilding Transformer box for Apogee Full Range
Old 1st May 2013, 06:17 AM   #11
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by 90493m View Post
direct drive the TW should be easy - can either just use series capacitor to block dc (Clayton s40 amp should handle the 1 ohm load ok)
I do not recognize any of the pictured circuits as a DC servo. I just do not see the large non-polarized caps used for DC integrators that I normally use. Perphaps another reader will know how to adjust the DC offset level. Your DC direct ribbon experiments prove how important a 1-2mv DC offset is for optimal direct drive safety. I would not personally put a DC servo on the RELAY PCB on the rear panel, but Krell engineers might have selected that location because of access to the output signal.
Your Clayton S40 amp only has 4 output transistors per channel. Your owner's manual would likely spec the maximum continuous power into 1.2ohms. My DIY ribbon amps have 20 * 180-watt outputs/channel for a 1 ohm ribbon. You may end up using the Apogee 4-ohm tweeter interface to avoid damaging the Clayton S40.
Let’s suppose you want to experiment with the reduced driver overlap of a 24db/octave acoustic slope.
FOR MID-TWEET… you use the standard Apogee Xover box wired for Tri-Amp which has a 4-ohm impedance that the Clayton S40 will like, and the Apogee capacitor-based passive 6db/octave slope at 4000hz. You program your active Xover for 18db/octave at 4000Hz and together you have a 24db/octave slope acoustic Xover. This combination is NOT EXACTLY the Linkwitz Riley ganged equation. For the midrange ribbon Xover, you use the 4-ohm transformer connected to the Krell KRS200, and program your active xover to 4000Hz at 24db/octave to match the tweeter. Again, maybe not a perfect match to the tweeter.
FOR BASS-MID: You program your bass active Xover for 24db/octave at 200Hz for both the bass and midrange. A 24db/octave Xover at 200Hz will put less bass energy on the delicate midrange ribbon than the original 6db/octave crossover at 400Hz. Direct drive the 1.8 ohm bass panel. Use the 4-ohm transformer for the midrange ribbon, adjust Xover gain for equal SPLs.
One Xover experiment completed! No amp destruction! No ribbon destruction!
Old 1st May 2013, 07:27 AM   #12
90493m is offline 90493m
thank you LS
as always your knowledge and insight are most appreciated! I think we are getting to the point where i am well armed to find the best combination of amps and crossover components.
I will keep everyone informed of my progress!
PS - will ask Krell where and how the dc offset is adjusted as well as the bias. one piece of good news - i measured all the caps on the driver boards and they are all within 5%.
Old 6th May 2013, 05:31 PM   #13
LS-
have you replaced the caps in your transformer box? if so i would be interested in what brand cap you used to replace them with. If i just stick with bi-amping the logical upgrade, other than possibly re-winding the MR transformer to 1 ohm would be to upgrade the stock caps and resistors. Just wondering what your experience has been with upgrades?
Thanks again LS
PS - even in their stock form the sound from the FR with the KRS is really lovely.
Old 10th May 2013, 04:00 AM   #14
LineSource's Avatar
LS-
I have not replaced the standard capacitors. They are now about 20 years old, and I do not hear any distortion. Good time to measure them for deterioration.
"Out of sight, out of mind".. :-)
Have you experimented with a steeper Xover slope between the bass panel and mid-tweet Xover? LR4 24db/octave slope at 200Hz should be a safe, simple experiment with your active Xover hardware. An experiment like this might help your future decisions for mid, tweet Xover slopes and frequencies.
Rebuilding Transformer box for Apogee Full RangeHide this!Advertise here!
Apogee Full Range Crossovers edbk Planars & Exotics 27 10th September 2013 09:24 AM
Direct driving Apogee Full Range speakers 90493m Planars & Exotics 23 17th April 2013 11:46 PM
FS: Apogee Caliper Signature full-range ribbon speakers andyjevans Swap Meet 1 22nd September 2010 12:33 PM
Full range in a closed box? Racket Scientist Full Range 4 21st August 2010 06:58 AM
full range box size when using a subwoofer pforeman Full Range 27 22nd March 2009 11:27 AM
Copyright ©1999-2017 diyAudio
