Bookshelf/Desktop ESL's Bookshelf/Desktop ESL's - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 28th March 2013, 04:20 PM   #1
MeTarzan is offline MeTarzan  United States
MeTarzan's Avatar
Default Bookshelf/Desktop ESL's
What is the reason that you don't see any small ESL speakers? Is there a mechanical drawback? Diminishing returns in quality as size decreases? I was looking for a small ESL project to get some hands on experience in order to get a better understanding of the process. Not even looking for something that really sounds great, just something that is small and works.
Old 28th March 2013, 05:13 PM   #2
tyu is offline tyu  United States
The Electrostatic “Sonic Panel” – Interview with Charlie van Dongen and Rob Mackinlay
Look here ....an theres more....good luck
Old 28th March 2013, 05:22 PM   #3
MeTarzan's Avatar
I was looking at those, $450 Aussie. I am sure they sound great but out of my curiosity price zone. I am finding more threads the more I look and all searches seem to bring me back here.
Old 28th March 2013, 05:28 PM   #4
SyBorg is offline SyBorg  United States
I just recently completed a set of small panels 12" x 12" to get my feet wet in the ESL realm. They would make fine bookshelf speakers, but certainly need a subwoofer (2.1 type of system). They do not offer room-filling sound levels, but are quite satisfactory for a small room. I'm using them in my office and they do quite well.
Check out Jazzman's DIY Electrostatic Loudspeaker Page
Jazzman's build page for lots of great info.
Old 28th March 2013, 05:34 PM   #5
MeTarzan's Avatar
Yah I read your thread and those are very close to something I would like to try. I am really into using cigar boxes for projects and surely have a couple matching boxes around the same square inches I could use for frames. 2.1 for sure if I can actually get some decent sound from the pair. Will reread your thread again. Hope your upgrades turn out well. Thanks for reply.
P.S. Gee Sy, this is a real groovy apartment you've got here...
Old 28th March 2013, 07:40 PM   #6
geraldfryjr is offline geraldfryjr  United States
All I ever build are Desktop ESL's !!
I am surprised you haven't seen them yet !!!
I may be the only one whom has ever done this.
I made my first ESL's as shown in the pictures in 2003.
Here are some of the links to my builds,
A Desktop ESL Build
A Segmented Stator Desktop ESL
The two systems I have shown in the first link can be found in many of the threads here at DIYAudio.
Enjoy !!
jer
Old 28th March 2013, 08:04 PM   #7
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
I started my experiments with small panels some years ago.
After I heard them became not statisfied with bass and mid range output.
So next experiments came out larger and larger.What I built at last can cover down to 85 hz or even less but at reduced output.
A small panel can be made to sound well, but you will need to make a hybrid speaker with a cone bass driver and ESL, crossed over lets say between 400 and 1kHz depending on its size.
Building a line source element(lets say, 10x100 cm) would yield good vertical dispersion pattern and acceptable horizontal even from a flat perforated sheet.
A square element with the same area would have somewhat more low end extension but would be extremely directional.
Good luck.
Lukas.
Old 28th March 2013, 08:14 PM   #8
MeTarzan's Avatar
Excellent and thanks for the links. Heading that way to browse now. At this point I would be happy building ESL tweeters! Just want to "do it" before I "DO IT". If they sound well (which would be a bonus to actually just working) I will pair them with a small sub.
Old 28th March 2013, 08:19 PM   #9
You will be amazed as to how well even a little set can sound if done properly !!!!
Jer
Old 29th March 2013, 02:48 PM   #10
WrineX is offline WrineX  Netherlands
WrineX's Avatar
i was wondering if there was enough interest to create of the shelf panels. with Pcb as stator material. with slots or drilled holes.
i might get me a plate of 1 mm thick 51 cm x 115 and cut some prototypes. in like 10 x 25 cm panels ? for mid and high frequency's ? with some support dots for the foil they could reach down to 300 hz with some efficiency to.
Bookshelf/Desktop ESL'sHide this!Advertise here!
Hum in my ESL's WrineX Planars & Exotics 3 29th December 2012 05:05 PM
Subwoofers and ESL's Vaughan Subwoofers 22 28th October 2012 09:28 PM
are ESL's, planars etc for me? mrkramer Planars & Exotics 30 28th July 2010 12:55 PM
ESL's and humidity? Few Planars & Exotics 10 6th August 2007 07:09 PM
What amp best for ESL's..? Adam Solid State 17 30th September 2002 03:33 AM
Copyright ©1999-2017 diyAudio
