Yet another DIY AMT Yet another DIY AMT - Page 4 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Yet another DIY AMT
Yet another DIY AMT
Old 27th March 2013, 07:45 PM   #31
solhaga is offline solhaga  Sweden
A further comment on #23.
The pleats have to be as parallell as possible.
I´ll simulate that later.
Old 27th March 2013, 09:46 PM   #32
It doesn´t seem to matter how I simulate the membrane, there will always be fields in the wrong direction.
So it´ll be a traditional motor mount with a traditional membrane orientation.
It´s time to looad the magnets...
Old 29th March 2013, 08:39 PM   #33
Default Assembling the motor, pt 2.
First I made dummies for the gap, to keep the space open and stopping the magnets from intruding it.
Then mounted the dummies and loaded the first set of magnets.
I will probably load one complete side as the next step. I only got two clamps long enough, so it will have to be it two sessions.
Old 30th March 2013, 01:32 PM   #34
Default Simulated rods vs solid
In the inverted motor I was able to study what happened with the field with respect to offset or rounded edges of the rods.
What if the iron was solid instead of 3 mm rods with 3 mm space inbetween?
The first three below is the rod simulation and the second three is with solid iron. Note that the layout is just for simulating the field, it is not the real motor.
So the field is actually higher with rods, even if it is not so linear.
Old 1st April 2013, 06:46 PM   #35
Default Assembling the motor, pt 3.
So I mounted some more magnets, painted the motors black in order to hide some of the imperfections. Then I made some baffles.
Now I´m waiting for the 3M tape to arrive.
Old 1st April 2013, 07:17 PM   #36
båndsei is offline båndsei  Denmark
It is looking good,and you are making a stereo pair.
How many pleats and what´s the depth of them?
Distance from top to top?
Bernt.
Old 1st April 2013, 09:02 PM   #37
To be honest, I don´t know. Yet.
It´ll be a lot of experimenting and I must first learn how this motor behaves.
The only thing I really know is that I will be using your excellent technique with the Alu on paper foil together with the 3M 74 Tape.
So folks, I have been waiting a long time to be able to say this:
Pleats, don´t fail me now!
Old 4th April 2013, 04:35 PM   #38
Default First membrane
I thought of having a simple layout at first.
The gap is 120 mm wide so why not have a 7,5 + 2,5 mm layout with 5 mm Alu strips.
The pleats are 7,5 mm deep and 2,5 mm apart.
That´ll be 120/2,5 = 48 pleats.
Unfolded the membrane is 48 x (7,5 + 2,5) = 480 mm.
So I cut a nail strip into 200 mm long strips to build a pleating tool:
Old 4th April 2013, 05:53 PM   #39
I have been calculating a bit.
I use 30 pleats in my latest model,and with 5,5mm stripes i get 3,8 ohm.
I recomend you to use 7,5mm stripes for low impedance and to cover more surface with alufoil.
I have another tool in my mind to get paralel pleats.
Your nailstrip is only 1mm.It might be better with 2,5mm.
Keep up the good work.
Bernt
Old 4th April 2013, 07:40 PM   #40
This was what I had at home. Just to get started.
But I wonder if the strips really has to be 2,5 mm in order to get 2,5 between the pleats.
I can easily have spacers to make the 2,5 mm with 1 mm strips if needed.
But I guess I´ll soon find out.
Yet another DIY AMTHide this!Advertise here!
Diy AMT båndsei Planars & Exotics 779 3rd October 2016 02:56 PM
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 09:17 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 06:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 11:17 AM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 03:16 PM
Copyright ©1999-2017 diyAudio
