Planars & Exotics ESL's, planars, and alternative technologies
Yet another DIY AMT
Yet another DIY AMT
Old 3rd July 2013, 08:22 PM   #231
solhaga is offline solhaga  Sweden
Membrane with 6/2 folding ratio, 4/4 alu. Blue measurement with wave guide. Red is a 8/2-membrane:
Improvements in hf (+20 dB @ 20 kHz) as predicted and higher lf cutoff (+100 Hz) as expected.
Vibrations? Yeah, sure!
Maybe it must be a three way system anyway
Old 4th July 2013, 06:58 AM   #232
båndsei is offline båndsei  Denmark
You will get lower distortion with 6/2 alu/space I have tried it.
Bernt
Old 21st July 2013, 08:45 PM   #233
Hawthorne have a AMT that plays from 500hz.Dimensions of the diaphragm is mentioned in this post :Hawthorne Audio • View topic - John's Rainier and Little Tahoma Build
Bernt
Old 21st July 2013, 09:43 PM   #234
That would be around 160 mm (high?) times 194 mm (wide) with 6,35 mm deep folds.
For sure, that must be the un-folded dimensions, or isn´t it this AMT?
Old 21st July 2013, 09:51 PM   #235
Default New magnete assembly
I will now try to experiment with a new magnetic structure.
This time it will be designed for a 60 mm wide and 160 mm high membrane.
The field gap is still 10 mm.
View from above:
Rods will be laying down with a 10 mm spacing will a slighty rounded shape and 4 mm thick.
Here´s a imaginary inverted view from the side:
The membrane will ba a lot easier to build and the grid will affect the sound less.
It will also be easier to make adjustment to the membrane once mounted.
Old 21st July 2013, 09:57 PM   #236
Simulations:
A hint of the variations in the field due to the spaces between the rods:
Old 21st July 2013, 10:06 PM   #237
Baffled up they are really thin:
Yes, I´ve made room for two aside:
Close up of the grid:
Old 21st July 2013, 10:14 PM   #238
I have no membranes made yet, so I used one I got from båndsei:
This is how it measured compared to when it was inserted in the old motor:
(blue is the membrane in the old motor, green is the membrane in the "mk II" motor with a simple baffle)
Old 22nd July 2013, 05:33 AM   #239
You are right about the dimensions on the Hawthorne AMT .But I dont think it is the unfoldet too.
I found another post with better Pictures:Hawthorne Audio • View topic - Silver Iris Reference AMT official thread
Bernt
Old 22nd July 2013, 06:02 AM   #240
Let´s says that the pleat width is 1,5 mm.
194/(1,5+6,35) equals 25 folds.
Looking carefully at the picture, couldn´t that be the case?
Yet another DIY AMTHide this!Advertise here!
Diy AMT båndsei Planars & Exotics 779 3rd October 2016 02:56 PM
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 09:17 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 06:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 11:17 AM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 03:16 PM
Copyright ©1999-2017 diyAudio
