Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Planars & Exotics ESL's, planars, and alternative technologies |
#21 | |
Basically the electrostatic equivalent of a permanent magnet. So, an electret speaker or microphone can be thought of as an ESL that doesn't require a HV bias supply. It's main use has been with microphones, but it has been used with some success in headphones. |
#22 | |
I think Stax made ESL headphones both ways. If excellent for mics, why not speakers? Why not DIY? Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and working on a folded 18-foot Voigt pipe) |
#23 | |||
Understanding & Using Directional Microphones Quote:
It is hard to tell without seeing your ESLs, but I think in your case the stators work as resonators, which dominate the top response. Does it make sense? Best, M |
#24 | |
Best, M |
#25 | |
Unfortunately the microphone test panels I was playing around with are still boxed up somewhere due to a recent move. However, attached is a pic to give you an idea of what the stators look like. Large holes in thin metal to minimize added acoustic mass. If interested, I can post some measurements later this month when I locate them. Last edited by bolserst; 5th March 2013 at 02:55 PM. |
#26 |
bolserts,
If I remember correctly most perforated screens such as you are showing have about a 50% open to closed surface area. You would think that would be a lumped impedance in your calculations when doing your modeling? Is it a factor or is the impedance low enough to air at the frequencies we are talking about in a mic to leave that factor out? |
#27 | |
Best, M |
#28 | ||
Once you start using diaphragms thinner than 1/4mil(6uM) it starts to to dominate the roll-off behavior. Quote:
But, it is easy to test if there is a resonance in the top octave. We should see the phase wrap if it passes thru a resonance. I don't recall seeing this in any of my measurements, but I wasn't exactly looking for it either. Question...if this was the case, would you expect to see a similar resonance in the top end of all ESL speakers? I'm 99% sure this is not the case for ESL speakers where the diaphragm is the driving force rather than the air motion thru the stators. I've been surprised before by the difference in behavior when a transducer is used as a microphone vs a speaker, so keeping an open mind...it's the only way to learn ![]() |
#29 | |
Basically theoretical prediction should be backed up by measurements of some sort availability of which I do not know. I think modeling these effects theoretically would be insanely difficult as we have gas which behaves like fluid, so not only open area matters, but hole size, spacing between holes, its shape, sharpness of the edge etc etc. Regards, Lukas. Last edited by Bazukaz; 5th March 2013 at 04:59 PM. |
#30 | ||||
I won't be able to give you any analysis of what difference the stators make. I'd think they do, as any obstacle is... an obstacle, and if anything, has its damping properties--after all, this is customary to put damping circles in front of dome tweeters (look at the ScanSpeak D2904, or Seas 27TAFNC/G). Of course, the easiest and quickest way to know would've been just to measure with and without, but unfortunately, we cannot make the ESL to work without stators ![]() Quote:
Also, many condenser microphones capsules also have it, Oktava MC219, MC319, many Audio Technica's. Heck!--even venerable WM60/61 also do have it! Unfortunately, for many reasons I won't be able to publish here development data of our own Samar MF65 ribbon mic to fully illustrate the process of frequency response tuning, but I can assure you, as Viagra salesmen use to say: "It works" ![]() ![]() Best regards, M Last edited by Marik; 5th March 2013 at 09:03 PM. |
Thread | Thread Starter | Forum | Replies | Last Post |
Electrostatic speakers | electros | Planars & Exotics | 23 | 26th March 2012 04:45 PM |
Calibrating microphones and speakers | Wavebourn | Solid State | 56 | 13th June 2009 04:24 PM |
Anyone had an experience of electrostatic speakers? | Test Electrix | Multi-Way | 1 | 16th March 2009 02:27 AM |
electrostatic speakers | junglejuice | Planars & Exotics | 3 | 22nd October 2001 09:32 PM |
New To Site? | Need Help? |
