Planars & Exotics ESL's, planars, and alternative technologies
Martin Logan CLS - Frame Dimensions
Old 4th February 2013, 06:28 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Martin Logan CLS - Frame Dimensions
Hey all,
Can someone help me out here? I am fabbing a pair of Cherry frames for ML CLS Panels and need dimensions.
The ML site says original CLS was 60" high by 28" wide, and newer CLSII were 57.5" high and 28" wide...
Question is what are your true dimensions? Is it 1" thick?
Inner "window"? I am thinking 22.5" x 48". How about the insert slot for the panel? 1/2" wide x 1/2" deep? is it straight , or curved lilke the panel?
Apprciate the help...Thanks!!
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 7th February 2013, 09:11 PM   #2
john65b's Avatar
Anyone??
Old 8th February 2013, 01:26 AM   #3
bigfishe is offline bigfishe  United States
I can measure friday
Old 8th February 2013, 01:42 AM   #4
SyBorg is offline SyBorg  United States
I have a pair of CLSII, Serial numbers 313 and 314.
The window is smaller on the front than on the back (much like a picture frame), and notched into the frame. It bevels toward the back on the right and left but is flat at the top and bottom
Outside overall dimensions: 29"W x 57.5H x 1.25" thick
Window dimensions (front): 22" x 48.75"
Window dimensions (back): 23.75" x 48.75"
The window is not centered vertically, much smaller space at the top than the bottom. The crosspiece at the top is 1.75" wide.
Hope this helps!
Old 8th February 2013, 02:02 AM   #5
john65b's Avatar
YES!!
Thank so much!!
Old 8th February 2013, 03:51 AM   #6
john65b's Avatar
One more question...
Are the slots in the side straight or curved to match the panels?
Old 16th February 2013, 08:37 PM   #7
Sorry, been away from the computer for a while. Here is a detail photo...Click the image to open in full size.
Old 16th February 2013, 10:51 PM   #8
The photo in the last post was taken from the back. It is tough to tell, but the opening is beveled front to back. If I had to guess how there were made, the side pieces probably had a slot cut into straight into them with a dado blade, then the slotted side was cut at an angle (i.e. ripped through a table saw with the blade angled.) The sides of the slot go straight back - no curve to them - as if they were cut with the dado.
Old 22nd February 2013, 12:43 PM   #9
john65b's Avatar
OK. I thank you for your help...I am building frames out of Cherry and are using your exact measurements - the slot appears about 1/2" wide and 3/4" deep to me....straight back...
Good deal. Thanks again. I will post pics after I am done.
Old 5th April 2013, 12:43 PM   #10
john65b's Avatar
Ha!! Done. I now have a pair of Oak frames...I have modified Acoustat MK-121-2A Interfaces on them. The panels fit nice and snug. Just waiting for them to fully dry...
Who hoo...
Martin Logan CLS - Frame DimensionsHide this!Advertise here!
Martin Logan CLS Power Supply john65b Planars & Exotics 63 28th December 2014 05:07 AM
martin logan cls Williams Audio Planars & Exotics 1 4th October 2012 10:38 PM
Martin Logan CLS panels - new Mylar trondareo Planars & Exotics 1 11th October 2009 06:34 PM
Martin Logan CLS Panel Refurb GlidingDutchman Planars & Exotics 0 10th March 2008 03:26 PM
Copyright ©1999-2017 diyAudio
