Planars & Exotics ESL's, planars, and alternative technologies
DIY ESL Pannel Parts Shopping in EU.
Old 31st January 2013, 10:26 AM   #11
Ulf Eliasson is offline Ulf Eliasson  Sweden
Question Full Range Transformer
Originally Posted by CharlieM View Post
...As I said earlier, this setup is not suitable for a full range ESL...
Any experience on what transformers we needed for a full range ESL and why?
Old 31st January 2013, 10:55 AM   #12
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Read my post #8 in this thread.
For full range ESLs you need mains toroids that have higher voltage on the outer winding to prevent core saturation in low frequencies.
1) For A semi-full range crossed to a subwoofer in 70-100Hz 12:230V transformers should be enough assuming active crossover is used. That's if you don't plan to use amplifier more powerful that about 80W/8Ohm.At least 4 or better 6 will be needed to obtain a reasonable total turns ratio.
2) For a complete full range no less than 20:230V transformers may be required and one would end up having to use 8 of them just to get turns ratio close to 1:90. IMO that would be more expensive than buying specialized trannies.
Old 2nd February 2013, 11:48 AM   #13
john65b is offline john65b  United States
john65b's Avatar
Bazukas, You are using a LM3886 on ESL panels? That poor amp! What rails are you at? How's it sound?
I have always wanted to try them (I have a few LM3886 and LM4780 modules just sitting around)
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 2nd February 2013, 01:38 PM   #14
Bazukaz's Avatar
To me it sounds good. I would not consider it a poor amp. Low distortion and robust. Has a current limiting of around 11.5A according to datasheet which is not bad either. However quite sensitive to PCB layout.
I am running it at +/-34V.
DIY ESL Pannel Parts Shopping in EU.Hide this!Advertise here!
Obtaining O2 parts in the EU timpert Headphone Systems 30 31st August 2011 10:26 AM
f5 - shopping parts. Cassiel Pass Labs 11 23rd May 2011 02:39 AM
Hong Kong/Shenzhen audio and diy shopping? Nisbeth Everything Else 2 21st October 2010 02:34 PM
Diy Ribbon Tweeter For ESL PANNEL. pmscompany Planars & Exotics 10 1st July 2006 03:15 PM
Speaker parts source in EU? bungaman Parts 0 27th October 2003 02:52 PM
Copyright ©1999-2017 diyAudio
