Planars & Exotics ESL's, planars, and alternative technologies
Coax speaker cables?
Old 1st March 2013, 12:23 PM   #31
CharlieM is offline CharlieM  United States
CharlieM's Avatar
Sanders' white paper favors cables with medium resistance, over larger cables with lower resistance, for driving the stat panels. I know that many ESL's require a resistor at the input to the transformers to tame the resonance generated by the interaction between the panel/transformer capacitance and the transformer's leakage inductance. I don't claim to understand all this; just stating what I've read from many sources. For example; the spec sheet for Plitron's ESL transformers recommends placing a 1-Ohm resistor in front of the transformer, for starters, followed by measurements and tweaking the value up or down as needed to keep the resonance above the audio band. Some guys on this forum could whip up an equation, plugging in the panel and tranny capacitances and leakage inductance and tell you exactly the amount of added resistance needed in front of the transformer to tame the resonance. Unfortunately, I'm one of the 5/4's of the population who struggles with math!
I think Sander's point is that, since some resistance is needed in front of the transformers to tame the noted resonance, you may as well allow the cables to supply a portion of that resistance; especially if using less copper in the conductors would help further reduce the cable's inductance and/or capacitance. Perhaps someone who understands this better than I will jump in and comment here.
In my speakers, the woofers are powered separately through different amplifiers and different/larger cables, so it's not like those 14-GA Mogami's on the stats are driving the whole load anyhow.
Old 1st March 2013, 12:39 PM   #32
john65b is offline john65b  United States
john65b's Avatar
Yes, as someone here explained it to me in laymen's terms, the series resistance on the amp output / esl input (in this case, the cables) is there to give the amp something to work against (as opposed to a low low dc resistance of the transformer alone)...
It was an easy way to get all my amps to play nicely with my Acoustat Model 3 - put in a series resistor of 1 ohm - otherwise only the Krell clone would drive the M3s well...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 3rd March 2013, 02:04 PM   #33
john65b's Avatar
Whoops, just realized I owe some pics
Old 25th April 2013, 05:23 PM   #34
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Is your film back from the developer yet....?
Old 27th February 2014, 07:32 PM   #35
Andersonix's Avatar
Dying of curiosity over here...
Old 27th February 2014, 07:42 PM   #36
john65b's Avatar
Whoops, I am a bit behind. I also noticed that these cables are not Sanders cables but some other brand. They came 2nd hand with my 10c
Old 27th February 2014, 08:07 PM   #37
CharlieM's Avatar
I'm now using the Mogami single coax cables on the woofers and these DIY cross-connected dual Belden coax cables on the ESL panels.
Old 27th February 2014, 08:38 PM   #38
tyu is offline tyu  United States
Thanks for the info............Vary cool speaker wire jazzman
Old 27th February 2014, 10:43 PM   #39
john65b's Avatar
Well finally took a look...they are not Sanders Cables...
Bass: Mogami 3103 2 conductor 4.0 mm2 OFC Speaker Cable - Japan - E137383 (UL) CL2X 75C 12 AWG
Treble: Mogami 3082 COAX 2.0 mm2 OFC Speaker Cable - Japan - E137383 (UL) CL2X 75C 15 AWG
Old 28th February 2014, 12:08 AM   #40
Andersonix's Avatar
Thanks to both John and Charlie for the updates!
Coax speaker cables?Hide this!Advertise here!
Balanced interconnect with 2 x 75 ohm coax cables? judderod Analog Line Level 56 4th March 2012 09:47 AM
Separate Coax Cables for + and - Signal? fred76 Digital Source 0 23rd May 2007 05:38 AM
AES/EBU coax cables sensitivity to cable length? miksin Digital Source 9 15th August 2006 12:16 PM
selenium coax speaker question darth_sanchez Multi-Way 113 25th March 2005 02:27 AM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 07:14 AM
Copyright ©1999-2017 diyAudio
