Planars & Exotics ESL's, planars, and alternative technologies
Explaining the Quad ESL-57 Crossover
Old 4th December 2012, 01:39 PM   #11
lcsaszar is offline lcsaszar  Hungary
These are static capacitances, but how do you take into account the radiation resistance of the air mass load, when the diphragm is moving?
Old 4th December 2012, 02:08 PM   #12
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
Interesting question. Radiated energy is a loss, so it should add an additional resistive load in the circuit.
I have no idea what the value is exactly. I think it should be insignificant to overall behavior of the circuit.
If a real world panel is measured IMO there should be some difference in impedance vs frequency when bias is connected or not, from that you could in theory calculate back load resistance.
BTW this also suggests that frequency response will change somewhat depending on bias voltage.
I might be completely wrong as well.
Lukas.
Old 5th December 2012, 08:23 AM   #13
Right, since the efficiency is about 0.1%, the radiation loss (that't what we hear) could be neglected.
Old 5th December 2012, 10:30 AM   #14
Bazukaz's Avatar
ESL's have very high efficiency but usually low sensitivity.
It is not the same.
The radiating area of ELS element is large, so coupling between the film and air is good and losses are minimal.
The problem is with amplifiers which have to dissipate almost all the power. Class D behave much better here as it can pump energy back into power supply.
Lukas.
Old 6th December 2012, 10:29 PM   #15
sheep is offline sheep  Canada
The ESL57 speaker has a real impedance component, that is the amount of power going into it.
It might have a sensivity of 87dB per Watt at 1m distance.
Old 7th December 2012, 09:42 AM   #16
87 dB? I suppose it is not more than 82 dB...
Old 7th December 2012, 10:40 AM   #17
Bazukaz's Avatar
According to manufacturer quad esl 57 has a sensitivity of 93 dB.
87 is still reasonable for the tweeter unit after aging but 82 likely indicates a problem.
Lukas.
Old 7th December 2012, 01:31 PM   #18
Lukas, I read in the original leaflet (http://www.quadesl.com/graphics/quad...cs/quaddia.gif) that the maximum output is 93 dB at 6' distance in its full range, which is 50 c/s to 10 Kc/s.
Now originally it was paired with the Quad II valve amplifier rated at 15 W. We can assume that 15 W resulted in 93 dB SPL (synergy between Quad components). 1 W gives about 12 dB less output, that is 81 dB. I don't know if dipoles follow the same law, but point sources give 3 dB increase with halving the measuring distance. So from 6' to 3' it gets 84 dB/1W/1m... Please correct me if my calculations are wrong.
Old 7th December 2012, 03:50 PM   #19
Bazukaz's Avatar
As far as I know, point sources drop by 6 and not 3 dB when distance is doubled. Larger planar surfaces drop at about 3 dB.
Indeed, it looks like specification is for max. output:
a) 93 dB@2m for 50 Hz.. 10 kHz
b) 100 dB@2m for 70 Hz.. 7 kHz
We can calculate in a different way as well. Max. input voltage for esl 57 as specified by quad is ~33 Vpk before arcing. Thats around 23.4 Vrms.
Expressed in dB and compared to 2.83V that is :
delta = 20* log(23.4 / 2.83) = 18.35 dB.
So for figure b) we arrive at sensitivity of 100-18.35 ~= 81.65 dB @ 2m
At 1 meter it should be around 85 dB.
However if measured at two meters this equals to a dynamic driver of around 87-88 dB because drop rate is more like 3 dB doubling the distance compared to 6dB for point sources.
Lukas.
Old 27th December 2012, 09:28 PM   #20
When I feed 4.4Vrms into the ESL57 @1kHz I get about 85dB at 1m.
So depends on the impedance curve, what is the voltage for 1W?
Explaining the Quad ESL-57 CrossoverHide this!Advertise here!
Quad ESL 57 panels? Simon T Planars & Exotics 5 8th February 2012 06:09 AM
Refurbing Quad ESL-57....Some Queries! Fanuc Planars & Exotics 14 2nd January 2012 11:12 AM
Quad ESL 57 connection discurio Planars & Exotics 3 20th April 2011 02:25 AM
QuAD ESL 57 Question dude007 Planars & Exotics 30 5th March 2010 07:45 PM
Quad ESL-57 (pair) TimA Swap Meet 2 14th November 2005 11:34 AM
Copyright ©1999-2017 diyAudio
