Planars & Exotics ESL's, planars, and alternative technologies
TPL150 DIY
TPL150 DIY
Old 13th October 2012, 12:08 AM   #31
ramallo is offline ramallo  Europe
ramallo's Avatar
TPL150 DIY
Thank you.
I tried a material similar to Bonded Logic, but thanks for the link.
The box have two types of fill, one on the wall is polyurethane foam and the other is wool filling the box.
With the first I added some absorption and increased the apparent volume of the box (The internal resonances going down in frequency), the wool is for decrease the Q of the resonances (by sharing the energy of the resonance in a greater number of frequencies), as well, the box have some braces for avoid some resonant modes of the walls (I did several waterfalls with a contact pickups). My first idea was do a losing cabinet (Like Rogers or Spendor) for expend part of the back energy on the walls. The box is made from 21mm baltic birch with the special rubber on the walls (very high density and weigth).
Not so much output at 5 kHz from the woofer, the piece in front of them partially prevents the output over 2kHz (Isn't designed for this function is just for high frecuency dispersion) (the woofer's low pass is much lower than the tweeter high pass)
Happiness is a warm soldering iron
Old 13th October 2012, 01:05 AM   #32
Lgrau is offline Lgrau  Denmark
Lgrau's Avatar
Originally Posted by studiotech View Post
Lgrau, any more picts of the whole system? Thanks.
Greg
The TPL is not yet integrated in a system, still experimenting.
Some pictures of my current(also unfinished) system can be found in my danish thread here:
HIFI4ALL Forum: Lyd laboratoriet
Old 26th October 2012, 04:20 PM   #33
Elias is offline Elias  Finland
Elias's Avatar
Originally Posted by ramallo View Post
Could not connect to User databaseUnknown database 'dev_diyaudio_forum'
I want to see too
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 26th October 2012, 04:26 PM   #34
ramallo's Avatar
TPL150 DIY
Originally Posted by Elias View Post
I want to see too
On "my gallery"
But, looks like a forum error
Old 26th October 2012, 05:26 PM   #35
moray james is offline moray james  Canada
[QUOTE=ramallo;3198701]Without the felt damping pad, the 2 order distortion drops 20dB[/QUOT
a question about the felt damping pad. what type of felt and what was the orientation of the felt? SAE rated F-11 is very broad band absorber and if you orient so the back wave strikes the edge surface of the felt rather than the flat it can make a big difference (same with fiberglass). Best regards Moray James.
moray james
Old 26th October 2012, 08:17 PM   #36
ramallo's Avatar
TPL150 DIY
[QUOTE=moray james;3216315]
The felt is the original and must be leave off (is glued to the metal body), this felt is very dense and this is the problem (probably with the age will lose his strength and then improve its measures).
But thanks for the tip
Cheers
Old 13th November 2012, 02:15 PM   #37
anubisgrau is offline anubisgrau  Serbia
What is the cheapest source for this driver at the moment?
Old 26th November 2012, 03:41 PM   #38
SEdwards is offline SEdwards
Hey guys I have a question about the resonant mode at ~1700 Hz. Can it be damped away by placing foam or a suspension on the diaphragm edges? I'm thinking about buying the membrane and doing my own mag circuit too. But I need output below < 1700 Hz, I expect.
Old 26th November 2012, 06:18 PM   #39
Lgrau's Avatar
Its hard to dampen, Ive tried some experiments using bitumen directly on the diagphram. It daemped the resonanse but it was also spreaded out.
If you want to below its better to buy the Aurum Cantus diagphram IMO with a fs around 1KHz.
I also wants to try this because I wanted to crossover around 1KHz
Old 27th November 2012, 06:35 AM   #40
That's a bummer. It looks like the Aurum Cantus has much poorer distortion figures. There is always a 'gotcha!' in audio it seems.
Where did you apply the bitumen? The sides or the tops or both?
It might be best for us to learn the best way of making these. It would seem that it requires manual labor which explains the costs. The traces are simply enough. Bandsei has made some pretty decent progress so far. Etching should not be too difficult with a mask or stencil, given the right foil.
TPL150 DIYHide this!Advertise here!
Beyma TPL150 vs Aurum Cantus 30130 comparison ? Paul W Planars & Exotics 4 26th April 2016 01:49 PM
Beyma TPL150 WG (H) wilbur-x Multi-Way 0 28th January 2012 01:47 PM
For Sale : Beyma TPL150 modern high efficient AMT Driver hum4god Swap Meet 1 26th March 2011 06:52 PM
Beyma TPL150 now with horn elac310 Planars & Exotics 14 9th October 2010 04:57 PM
Brand New Beyma TPL150 AMT FS thadman Swap Meet 1 22nd September 2009 09:26 AM
