Planars & Exotics ESL's, planars, and alternative technologies
Question for current ML CLS Owners
Old 27th September 2012, 06:08 PM   #1
john65b is offline john65b  United States
john65b's Avatar
Default Question for current ML CLS Owners
Hey all,
If anyone has ML CLS (any model) can you confirm what the seated dimension inside the frame is?
These panels flex in (compress) and fit inside the frame, and remain compressed - I am making my own frames and would like to know what that designed seated dimesion is - uncompressed panel is around 23.5" and I am guessing that the compressed dimension is 23"? Can someone confirm?
Also, I have confirmed that the bass of the CLS panel definitely improves with the panel compressed in the frame (haven't yet confirmed HF improves, but should with added tension).
I have a pair of panels that had a bad "Kazoo" problem that seems to lessen/go away if they are compressed further - seems to be that over time, the mylar gives a tiny bit and loosens up - maybe a simple fix to the "Kazzooing" is a shim between the frame and panel??
Anyway, I appreciate the help...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 1st October 2012, 06:17 PM   #2
john65b's Avatar
Any help??
Old 2nd October 2012, 12:33 AM   #3
AVWERK is offline AVWERK  United States
AVWERK's Avatar
If I understand what your asking and maybe I,m wrong but the width has nothing to do with compression but the slotted groove that clamps the front to back dim. Around the perimeter is what determines its rigidity?
The width should just be slightly snug?
One bad idea that the CLS did was to use hard woods that are too high Q that adds to frame resonance. It sure looks nice but if you could make a sealed area to add sand or better, this would surely look good and keep the frame inert. Painted MDF is another option and somewhat self damping.
David
Old 2nd October 2012, 12:56 PM   #4
john65b's Avatar
Hmmm, so the panel is not compressed into the frame adding additional mechanical tension to the membrane? Just slightly snug?
OK, I stand corrected. I made my frames (that the panels fit in) out of wall shelf mounts - (the ones that are 4 feet long with double slots where the shelf brackets insert). I made them exactly 23" wide and had to compress the panel (with new installed 12 micron mylar) into the frame...the mylar starts to "saddle" around the wider spacers...
Anyway, I will try them again uncompressed and see how they fare...
Thanks for the help!
Old 2nd October 2012, 01:30 PM   #5
tyu is offline tyu  United States
http://www.martinloganowners.com/for...6&d=1198872920
You know Search is your frend
Looks Compresses too me....goodluck
Old 2nd October 2012, 02:52 PM   #6
Here one...
This is funny....Magnepan owners for years have found that the MDF sounds like crap...an pay Big $$ for all wood frames...Wood takes bad vibs an turns them into heat an takes them away from the drivers...MDF feed it back too the drivers an sounds bad....I have heard the diff... it BIg...Martin logan new this.......goodluck
Old 2nd October 2012, 06:13 PM   #7
john65b's Avatar
tyu - yes, I have seen that vid, and yes, there does NOT seem to be much side compression of the panel - as AVWERK indicated - it appears just "snug"....
I replaced the mylar on the CLS with 12 micron aluminized (no coating) as a test and came out with decent results - I just have way too much side tension causing the "saddling" of the mylar in between wider spacers...since panel stators are not glued together, it takes no more than an hour to open the panel and re-mylar, so I can rip it all out and start over easily...this is ideal for routine cleaning and maintenance of panels.
Also - I don't know if Maggie owners ditch stock MDF for solid wood for any reasons but appearance.
Old 2nd October 2012, 06:23 PM   #8
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
If you use a diaphragm with aluminised foil rather than high-resistance coated foil, aren't converting your speaker from constant-charge to constant-voltage?
That would give a completely different behaviour.
jan didden
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 2nd October 2012, 07:39 PM   #9
I have a pr of stock CLS here an there compressed ....say what you well...hope that works out for you...
Well then you have not look at the mill post on all wood frams.....lot more than looks.... Magnestans... peter Gunn.Has done the work......but your not doing maggys now...i gess you can say any thing ....i try to say only what i have seen an heard!....goodluck
Old 3rd October 2012, 12:42 AM   #10
john65b's Avatar
Jan, Sorry,don't understand - is there a difference? Sorry for my Ignorance...the use of metalitized mylar was purely an experiment...not exactly sure what I think, it does work and produces nice sound...
I was thinking a high res membrane would not be able to recharge as quickly as a low res membrane, and thus be that much more responsive to music demands...
Thread where I got the idea for Aluminized foil (extremely cheap BTW)
Building an Electrostatic Speaker
Now discussions around the cons with Metalitized mylar:
http://www.diyaudio.com/forums/plana...tml#post574466
And the pros of using it from same thread (great thread BTW):
http://www.diyaudio.com/forums/plana...tml#post719626:
Question for current ML CLS OwnersHide this!Advertise here!
Opinions please...Tympnai IVa / ML CLS / Soundlab Pristine II john65b Planars & Exotics 21 5th November 2012 05:52 PM
Experience Stacking ML CLS john65b Planars & Exotics 2 11th May 2012 09:39 PM
Question for Heathkit W-5M owners ltarini Tubes / Valves 4 17th October 2007 04:48 AM
