Planars & Exotics ESL's, planars, and alternative technologies
Summer Project - Replication of MBL loudspeaker 101mkII
Old 30th June 2014, 11:15 PM   #71
Magnasanti is offline Magnasanti  United States
Magnasanti's Avatar
The testing stage is officially here all problems that hindered me in making a very accurate, reliable, and fast speaker have been solved. This New build will be a test of all of this after that changes in materials and construction will be tested and results will be shown here along with a recording.
Old 12th October 2014, 03:59 AM   #72
Magnasanti's Avatar
Default New Build on the horizon
A new build utilizing all of the new processes is in the works. I will be sure to include a recording and measurements soon after.
Old 12th October 2014, 10:02 PM   #73
karellen is offline karellen  Spain
nice models!
A cold amp is a sad amp... I like them warm at least
Old 16th October 2014, 12:15 AM   #74
Magnasanti's Avatar
Thank you Karellan. The process is working great although I did find a few kinks that werent anticipated in real life assembly. This will no doubt be the best most accurate assembly. The first few test will show a difference within the same mid-range unit. changes in "additions" that will will show a before and after effect. The ones after will be a whole other mid-range with a design that should increase sensitivity.
Old 17th October 2014, 03:36 AM   #75
Magnasanti's Avatar
Default Build
Part way through Only lamellas are attached no sealer yet.
Old 17th October 2014, 09:46 PM   #76
Magnasanti's Avatar
Default Build
Further along the build Almost ready for a listen. Could it fool you?
Old 18th October 2014, 03:34 PM   #77
The seal between lamelas looks very good
Very good craftmanship.
How it is done? Some kind of EVA?
Old 18th October 2014, 03:46 PM   #78
Magnasanti's Avatar
Thank you karellan the amount of craftsmanship needed is insane. The amount of research and development needed to make a system to allow for the perfect alignment of all elements far exceeds it. No it is not EVA. It is in fact Neoprene foam. There are several tricks in building this thing that one only will truly know if they build it and research the heck out of it. The actual alignment system I use is in my opinion a little more "correct" than mbl. All from what I seen tells me they may be a little out of plumb so to speak.
Old 18th October 2014, 04:13 PM   #79
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Very nice build quality.
Did you test each petal for equal tension under compression?
I would think any deviation would cause the coil to rock if they were not equal.
David
Old 18th October 2014, 04:19 PM   #80
Magnasanti's Avatar
Testing at every stage is crucial to know you will not end up with a messed up speaker. The most important thing to get all of the lamellas right and have to proper know how and equipment to place them. After that its simply a matter of careful hands. The speaker is finished there is a lag to when I post. Speaker has no apparent rock modes. only clean sound.
Summer Project - Replication of MBL loudspeaker 101mkIIHide this!Advertise here!
Summer Project - Replication of MBL loudspeaker 101mkII Magnasanti Planars & Exotics 77 21st November 2012 09:31 AM
Possible Summer Project bose301s Multi-Way 8 18th June 2009 12:25 AM
Possible Summer Project bose301s Multi-Way 8 29th May 2009 08:49 PM
Opinions on a Summer Project athos56 Multi-Way 19 13th May 2007 11:40 PM
Summer Project edjosh23 Multi-Way 19 9th June 2005 02:37 AM
Copyright ©1999-2017 diyAudio
