Summer Project - Replication of MBL loudspeaker 101mkII Summer Project - Replication of MBL loudspeaker 101mkII - Page 6 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Old 16th June 2013, 03:29 PM   #51
Magnasanti is offline Magnasanti  United States
Magnasanti's Avatar
Yes the render images are nice but you sadly cannot gather useful measurements from them. Karellen have you had time to listen to the mbl speakers? I am sure that they are simply attached to each other and the motor is on the bottom of both.
Old 17th June 2013, 09:18 AM   #52
karellen is offline karellen  Spain
I bet you can; 3ds was fully compatible with autocad, so if you dowload the model, almost certainly you can open it on acad, and judging for the quality of the model the dimensions should be real.
but I just guessing
A cold amp is a sad amp... I like them warm at least
Old 17th June 2013, 09:35 AM   #53
Default damping, compliance and density
Damping, compliance, density...
The neoprene is quite good on the three.
If the neoprene and the leather doesn't work well as inter lamelas sealant and damper, I will like to try something more advanced (and expensive), the sorbothane Sorbothane Sheets - 12" square, 1/8" thick | Edmund Scientific that looks like the neoprene, but with much better damping and compliance.
the problem is that maybe is very slow on recovering the shape...
I suspect that it is the material used by Mbl.
by the way... I've never had the oportunity to listen to the mbl speakers
Old 17th June 2013, 02:43 PM   #54
Magnasanti's Avatar
Yes I know very well the Sorbonne product. I know factually that mbl does not use this in the current 101mkii. You are welcome to try it and show me. Sorbonne is also extremely heavy compared to other materials. The density is 1.28 g/cm cubed.
Old 2nd March 2014, 04:29 PM   #55
Magnasanti's Avatar
Default Ray Tracing
Finished model. All parts are acquired time to get building. Improvements are all around from the ground up.
Old 2nd March 2014, 08:48 PM   #56
Magnasanti's Avatar
Default Ray Tracing
Sneak peak into the far future.
Old 12th March 2014, 08:52 PM   #57
Magnasanti's Avatar
Default semi
took a couple of days to attach the lamellas and such. The process is pretty slow and stressful. I am pretty happy with how it turned out so far.
Old 12th March 2014, 09:02 PM   #58
RobFreak is offline RobFreak  Denmark
At first i thought you were building a spaceship, until i realised it was a speaker. Very ambitious and great work. So the question is, when is the group buy?!
Old 12th March 2014, 09:12 PM   #59
looks very well!
please, go on.
I can't wait to see how do you seal the gap between lamelas!
Old 13th March 2014, 05:53 PM   #60
a.wayne is offline a.wayne  United States
Sin Bin
You have to get petals closer, way too much clearance ....
Summer Project - Replication of MBL loudspeaker 101mkIIHide this!Advertise here!
Summer Project - Replication of MBL loudspeaker 101mkII Magnasanti Planars & Exotics 77 21st November 2012 08:31 AM
Possible Summer Project bose301s Multi-Way 8 17th June 2009 11:25 PM
Possible Summer Project bose301s Multi-Way 8 29th May 2009 07:49 PM
Opinions on a Summer Project athos56 Multi-Way 19 13th May 2007 10:40 PM
Summer Project edjosh23 Multi-Way 19 9th June 2005 01:37 AM
Copyright ©1999-2017 diyAudio
