Planars & Exotics ESL's, planars, and alternative technologies
Summer Project - Replication of MBL loudspeaker 101mkII
Old 11th April 2015, 08:36 PM   #131
Magnasanti is offline Magnasanti  United States
Magnasanti's Avatar
Default Assembeld Playing speaker
The speaker has been assembled.
Old 12th April 2015, 08:30 AM   #132
gubrin is offline gubrin  Poland
gubrin's Avatar
Looks amazing.
Are you using vacuum infusion when making lamellas ?
Old 12th April 2015, 09:34 PM   #133
Magnasanti's Avatar
No I am not using infusion to make these laminates. I am just using a vacuum and a proper technique for the lay-up and post process. I really like the matt Finnish in these that matches the mbl look. This is due to using frekote as a release agent. This One I feel is pretty close to mbl quality I still need to work on a couple of things that if I decide to make another It will be simply for the purpose of making a perfect mbl quality driver. All others will be made for experimenting to achieve better than this control measurement.
Old 12th April 2015, 10:02 PM   #134
kevinkr's Avatar
It looks great, and the care in making and assembling is very evident in both the descriptions and photographs. I would not be surprised if at the end you end up out mbl'ing MBL..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th April 2015, 03:07 PM   #135
WrineX is offline WrineX  Netherlands
WrineX's Avatar
this thread is till one of the highest ranked in no compromise no cost object DIY. i many times wondered if this whas just for you or is there any comercial benefit to it >? everything is done so well. and never did something to skip on costs. its a sick thread to follow !
keep up the good work its verry interesting!!
Old 15th April 2015, 03:11 AM   #136
Magnasanti's Avatar
Thank you guys for the kind words. I would have never thought you guys would say the things you have to a wannabe MBL builder so it means a lot. No commercial benefits so far, maybe in the future. Any ideas what you guys would want? Let me tell you guys, this speaker is very challenging to build.
Old 16th April 2015, 01:39 AM   #137
Magnasanti's Avatar
This is the first speaker with no audible voice coil rub and buzz from any distance just clean sound a landmark which any builder of this speaker can be proud of. I will post videos later. Measurements will be done later when I get the stand made.
Old 16th April 2015, 03:28 AM   #138
Magnasanti's Avatar
Default Recording
Here is the recording hosted on sound cloud. Recording doesn't do it justice I think omnis are hard to capture as they sound different from room to mic. adjust volume as mic position changes.
https://soundcloud.com/david-salazar-134/untitled-3
Old 16th April 2015, 12:08 PM   #139
BigE is offline BigE  Canada
BigE's Avatar
Yes. I would want enough parts made to assemble two myself!
Old 16th April 2015, 07:43 PM   #140
gubrin's Avatar
Full plans (after all it's diyaudio) with comments ? ;-)
Ready made parts (such as lamellas, metal parts) ?
Full kits ? Partial kits ?
All of the above ?
On the other note, if you're going to make bass driver, do you plan to use thicker carbon fiber for lamellas or aluminium as on original MBL (it's probably next to impossible to diy them) ?
Summer Project - Replication of MBL loudspeaker 101mkIIHide this!Advertise here!
Summer Project - Replication of MBL loudspeaker 101mkII Magnasanti Planars & Exotics 77 21st November 2012 08:31 AM
Possible Summer Project bose301s Multi-Way 8 17th June 2009 11:25 PM
Possible Summer Project bose301s Multi-Way 8 29th May 2009 07:49 PM
Opinions on a Summer Project athos56 Multi-Way 19 13th May 2007 10:40 PM
Summer Project edjosh23 Multi-Way 19 9th June 2005 01:37 AM
