Planars & Exotics ESL's, planars, and alternative technologies
Suggestions for aluminium ribbon damping?
Old 20th March 2013, 12:15 PM   #101
audioquestM-40 is offline audioquestM-40  Canada
audioquestM-40's Avatar
Originally Posted by hanski View Post
The fine pitch was a success.
That corrugation looks almost identical in pleat size to my Apogee Scintilla ribbons. Nice work!
Krell KST100, Edge M4, Bryston .5b, Audio Research LS2B, OPPO 103, Moon 300d, MF A3.24, Oracle Alexandria SAE mc cart, Jasmine LP 2.0se phono, Martin Logan reQuest
Old 20th March 2013, 01:46 PM   #102
dacen is offline dacen  Norway
@ hanski. Thank you for sharing info and pictures. 3D printing? That is new to me. Any more info to the forum about that. Fantastic work! Impressive.
Old 21st March 2013, 02:09 PM   #103
RogerGustavsson is offline RogerGustavsson  Sweden
However even 0.6um thick foil has resonances and needs damping.
0.6 Ám sounds unrealistic to me. Maybe you meant 6 Ám?
Old 21st March 2013, 03:52 PM   #104
hanski is offline hanski  Finland
0.6um alu foil can be bought as "Imitation silver leaf foil".
At first it felt really thin, but when I started experimenting with leaf gold (0.2um)... oh man that's thin.
I used Sketchup for modelling the corrugator. A gear drawing plugin is available on the web.
Trimble SketchUp
Shapeways material called "Frosted ultra detail" is good for fine detail printing.
3D Printing in Frosted Detail Plastic on Shapeways
Old 29th April 2013, 08:40 AM   #105
Hi all,
I haven't had any luck in finding thinner than 6.5um foil.
so I started thinning down my foil with simple etching process (I used a strong alkali solution). See pic..
The results are as expected. Thinner foil has less resonances in 2 - 8kHz range.
Regardless of foil thickness, embossing seems to be more effective way of killing 2 - 8kHz resonances in pure alu tweeter ribbon than corrugation.
I wouldn't like to repeat the etching, and I woudn't recommend anyone to try it.
So a hint or a tip of thinner foil source would be very welcome, thanks.
Suggestions for aluminium ribbon damping?Hide this!Advertise here!
0.6my aluminium ribbon ABJensen Planars & Exotics 112 17th July 2013 01:55 PM
help with damping resonances in aluminium? mondogenerator Multi-Way 16 30th May 2013 03:44 AM
Ribbon tweeter/mid suggestions craigwalsh Multi-Way 13 1st November 2008 08:36 PM
want to build a DIY ribbon, need suggestions thadman Planars & Exotics 16 10th June 2006 06:39 PM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 07:33 AM
