Planars & Exotics ESL's, planars, and alternative technologies
Suggestions for aluminium ribbon damping?
Old 28th November 2012, 03:19 PM   #91
a.wayne is offline a.wayne  United States
Sin Bin
Hanski what are you using to dimple the diaphragm....?
Old 29th November 2012, 06:28 AM   #92
hanski is offline hanski  Finland
I just roll press the foil on a mosquito net (a kind tip from diyA member). then I corrugate the foil with shallow corrugation so that the embossed surface texture stays.
This procedure works with foil only ribbons.
Embossing is very effective way to kill ribbon resonances. And corrugation makes life so much easier with long ribbons due to compliance (springiness) it brings.
Btw, I've made also many other significant improvements to my system. I'll post the details later..
Old 29th November 2012, 08:58 AM   #93
JAMESBOS is offline JAMESBOS  England
Very clever, well done
HENRY
Old 29th November 2012, 02:52 PM   #94
Paul W is offline Paul W  United States
Paul W's Avatar
I've done both, but never together...neat idea!
Paul
Old 29th November 2012, 03:19 PM   #95
Sin Bin
You must be using a very soft foil , with little to no memory, i sill give it a try the foil I'm using is might not take the impression from the net so easy...
Old 30th November 2012, 07:33 AM   #96
Many things might affect to the result.
I'm currently using 6,5um thick capacitor foil. (My experience is that the thinner the foil, the better the sound.)
I attached a couple pictures to show my primitive methods.
I've three layers of mosquito net on top of particle board. The soft roller needs hard pressing to produce good embossed surface.
And I've rolled some tape on the corrugation gears so that there is an air gap between the gears.
This method doesn't work with plastic backed ribbons. It works with foil only ribbons.
Old 30th November 2012, 09:15 AM   #97
jernejx is offline jernejx  Slovenia
Thank for sharing whit us
Wher did you buy capacitor foil?
I have one home from my frien but it has 80ohm resistance on 1,5M lenght.
What resistance have yours?
Old 1st December 2012, 09:53 AM   #98
Jernejx, maybe you have a metallized film capacitor?
These type capacitors have very thin sputtered aluminium layer on top of plastic film. => the aluminium can't be removed from film.
I have tried my luck on buying film/foil capacitors from ebay and learned couple things:
-High voltage (20kV) film/foil capacitors are unusable (foil is too thick or can't be removed from plastic film)
-Low voltage caps (50V - 100V) have a couple drawbacks. Some of them are with tin/lead foil and many of them are not wide enough for midrange ribbon.
-I've had best luck with medium voltage caps (<0,5kV). They can be found wide enough to make midrange ribbons.
Old 20th March 2013, 10:56 AM   #99
Hi all,
here's some update of my system. First something about the ribbon headphones.
The headphones have been a great learning experience about ribbon resonances.
My experience is that the thinner the foil, the less resonances.
However even 0.6um thick foil has resonances and needs damping.
Damping is easy to do with an extra damping layer of something.
On the other hand I have found that damping materials take away resolution from music and can cause the music to sound veiled.
So minimal damping should be used.
My current headphones use 0.6um thick aluminium foil. The resonance damping is achieved by sandwich construction. Sandwich: 0.6um alu + thin layer of oil + leaf gold layer.
Talk about fragility..
It's not even possible to corrugate such structure. That's why they can and do rattle at bass notes.
And here's a picture.
Old 20th March 2013, 11:50 AM   #100
And then about the other system.
The basic loudspeaker design issues (SPL at lower freqs, and dispersion at higher freqs) force to use a multiway system.
I would love to build a single way system some day..
I quit using open baffles at lowest bass due to SPL issues. The woofers are sealed box and the rest of system is open baffle from 80Hz up.
The ribbons are still 6.5um thick foil, but I'm searching for a 3 - 4um thick foil.
I found that corrugations cause resonances, but on the other hand they are needed for stiffness reasons for the ribbon to produce lower midrange frequencies.
So I made a new corrugation roller by 3D printing. That way I got a fine pitch roller.
The fine pitch was a success. The fine pitch acts as the same as embossing the ribbon surface => reduced resonances.
It still needs some damping so I'm using a thin layer of spray contact glue on ribbon surface.
I would very much like to find alu foil in 3 - 4 um thickness range.
I feel that it would be still strong enough for a ribbon, but with reduced resonances.
Any suggestions are very welcome, thanks.
Suggestions for aluminium ribbon damping?Hide this!Advertise here!
0.6my aluminium ribbon ABJensen Planars & Exotics 112 17th July 2013 02:55 PM
help with damping resonances in aluminium? mondogenerator Multi-Way 16 30th May 2013 04:44 AM
Ribbon tweeter/mid suggestions craigwalsh Multi-Way 13 1st November 2008 09:36 PM
want to build a DIY ribbon, need suggestions thadman Planars & Exotics 16 10th June 2006 07:39 PM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 08:33 AM
Copyright ©1999-2017 diyAudio
