Planars & Exotics ESL's, planars, and alternative technologies
Diy AMT
Diy AMT
Old 5th January 2014, 02:53 PM   #421
solhaga is offline solhaga  Sweden
It seems that the response levels out at 2-3 kHz and then there´s the usual of peaks and dips above that.
Too heavy membrane in order to get better lower frequency response?
Isn´t the distortion a little bit high?
At what distance and angle do you measure and at what power level?
What´s your analysis, Bernt?
Old 5th January 2014, 05:03 PM   #422
båndsei is offline båndsei  Denmark
I measure at 1meter 2,8v. and app.15-20'
My magnets might be too week to control the heavier diaphragm.
Best result is with one layer of mylar,and 10my alu.
I have ordered 10x25x25mm neodyn magnets for my "kithara"magnetsystem,to test in a stronger field.
You used remount spray for your cutting.
Do you think it can be used for the cutting mat, as mine is not so sticky now.
Bernt
Old 5th January 2014, 05:25 PM   #423
I think you should measure as close as possible (10 cm?) and at 0 degrees when it comes to measure the distortion. This to avoid room, noise and early reflections in the measurements.
My magnets might be too weak to control the heavier diaphragm
Perhaps you could move the magnets apart in order to prove that theory.
Yes, that´s what the scrappers use to refurbish the mat.
Old 16th May 2014, 10:10 AM   #424
[IMG]Click the image to open in full size.[/IMG]
I have made some new models.
I have made a curved line of 4 amt´s ,did´t like it.4 amt´s in a Square, better.
And now 2 amt´s angeled 10'
I have not measured it ,but crossing at 500 Hz.sounds good.
Larger than my first model, placed on top.
Bernt
Old 16th May 2014, 12:08 PM   #425
karellen is offline karellen  Spain
Impressive collection!
A cold amp is a sad amp... I like them warm at least
Old 16th May 2014, 04:01 PM   #426
That's great.
Sure that you got the four AMTs in phase ?
Old 16th May 2014, 06:48 PM   #427
Thomas Spilcker is offline Thomas Spilcker  Denmark
I follow you with great interesse . ( On Facebook , we got a side WHO are called La Folia. )
Old 16th May 2014, 07:57 PM   #428
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Super cool båndsai
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 19th May 2014, 07:21 PM   #429
I have listened a bit more and tried different crosoverpoint's . 800 Hz might be better.
I expected the 4 amts to be better than 2. It's the same.
2x 170mm. AMT,s. Measured at 1m. 2,8v. on axis.
Thank you all for positive comments.
Bernt
Old 23rd October 2014, 08:02 PM   #430
Orgon is offline Orgon
You posted your pictures with imageshack, the thread is pretty much useless now...
Diy AMTHide this!Advertise here!
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 10:17 PM
DIY AMT: which of the three replacement diaphragms to use? capslock Planars & Exotics 3 4th July 2010 06:26 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 07:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 12:17 PM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 04:16 PM
Copyright ©1999-2017 diyAudio
