Diy AMT Diy AMT - Page 26 - diyAudio
Planars & Exotics ESL's, planars, and alternative technologies
Diy AMT
Diy AMT
Old 15th April 2013, 07:28 PM   #251
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Diy AMT
Originally Posted by Thomas Spilcker View Post
.....should be a old german produkt.
ahh...looks to me like it could a half 'Rubanoide'
Old 15th April 2013, 07:49 PM   #252
Thomas Spilcker is offline Thomas Spilcker  Denmark
Linaeum hôgtoner.de ?
Old 17th April 2013, 10:22 AM   #253
Diy AMT
yes, I think you are right..Lineum might be the original, and right generic term
but it is not AMT
there is another thread about it
http://www.diyaudio.com/forums/plana...rent-kind.html
Old 19th April 2013, 03:51 PM   #254
bsyoon is offline bsyoon
Default magnet system
I don't know why nobody try to test U-shape magnet system of MUNDORF.
Here is the result of mine.
Please point it out if something wrongs are there.
Old 20th April 2013, 07:33 AM   #255
solhaga is offline solhaga  Sweden
I´m not familiar of the Mundorf system. Could you explain for example what´s magnetes and what´s pole pieces?
The field looks strong and even. Could you simulate b.t and b.n separately?
Old 20th April 2013, 08:02 AM   #256
båndsei is offline båndsei  Denmark
I would like to see the femm.drawing too,and as solhaga wrote,it looks good.
I prefer the open model I use myself,but this one has stronger and more homogen field.
Bernt
Old 21st April 2013, 06:08 AM   #257
Attached my magnet system in detail.
There are 6 magnets of 40x25X10mm, N35 and the inner steels are separated each other to be attached on the magnets perfectly.
The gap between the inner steels doesn't affect to the flux density so much.
Old 21st April 2013, 09:15 AM   #258
Just did a simulation of a much slimmer design of my AMT with an air gap of only 40 mm.
I get the same b.n strength as yours but even in the whole gap 0 - 40 mm.
The b.t field is zero in the whole gap 0 - 40 mm.
It is also much easier to make with straight rods everywhere.
Old 21st April 2013, 10:02 AM   #259
Thanks for your reply !
Truly, the U-shaped magnet structure is not so simple to make.
I'd like to see your simulation.
Could you introduce your slimmer design ?
Old 21st April 2013, 04:03 PM   #260
Default Small AMT
"Could you introduce your slimmer design ?"
Here you go.
Diy AMTHide this!Advertise here!
AMT diaphragm DIY basics. graeme uk Planars & Exotics 2 9th December 2010 09:17 PM
DIY AMT: which of the three replacement diaphragms to use? capslock Planars & Exotics 3 4th July 2010 05:26 PM
big AMT Diy Charcoal Planars & Exotics 27 13th October 2008 06:41 AM
Diy Amt ? woody Planars & Exotics 0 24th September 2005 11:17 AM
Diy Amt JohnL Planars & Exotics 4 29th April 2005 03:16 PM
Copyright ©1999-2017 diyAudio
