Planars & Exotics ESL's, planars, and alternative technologies
Words best speaker?
Words best speaker?
Old 24th August 2012, 09:31 PM   #51
studiotech is offline studiotech  United States
Originally Posted by Remlab View Post
I wonder if you could make a poor(OK, Middle class) man's version of the LS-4 with an RD-75 (or nine Neo 8's) and 14 Neo10's. It wouldn't be as efficient, but it would be pretty much the same basic technology that could also be crossed over at the same 750 hz point and with about a 4000w peak power handling ability(with the Neo 8's). It could also probably do around 80hz. All for only $8,000 a pair(With a good dsp crossover added).. WHOOPEE!
I thought the same exact thing when the LS-4 was revealed. You could do it with pairs of mini Maggies flanking an RD series driver too. Too bad the small Maggies are only 'push' planars rather than push-pull. Efficiency is too low for my tastes, but they have more surface area(hence lower cut-off) than some Neo10s. I lived with MMGs for several years and was generally happy, but wanted more and the DIY bug bit again.
Greg
Old 24th August 2012, 10:23 PM   #52
Remlab is offline Remlab  United States
Greg
Radiating width is also a very important consideration. A neo 10/Neo 8/Neo 10 configuration on a baffle would be around 14" 0r 15". An almost perfect match to the LS4's radiating width.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain
Old 24th August 2012, 11:52 PM   #53
Go big or go home! These MMG W are 38" tall and 10" wide. Less if you remove the driver from the frame. Two stacked vertically matches the RD-75 pretty well and they are only $325/pr. That's right in line with the neo10, BUT waaayyyyy larger. Wire the pair on either side of the Rd-75 in series and then parallel those with the other side and BAM, back to 4 Ohms and plenty of surface area to dump a lot of power into. Cross to the RD-75 at about 500 Hz. I would make a nice framed cavity in the wall and stuff the crap out of it with Bonded Logic. I think I need a separate home theater now!
http://www.magnepan.com/model_MMGW
Greg
Old 25th August 2012, 12:25 AM   #54
I wonder if this stuff is just Bonded Logic sold under another name. I looked rather quickly for eco-core on Google and got lumber products and Ecocore sound insulation that is polyester, not cotton. Acoustimac is local to me, being just over in Tampa. Maybe I'll give them a call...
Greg
Old 25th August 2012, 12:50 AM   #55
MMGW - Magnepan, Inc.
Greg
Your right. That configuration would work with a 500hz crossover point. Very economical too(Relatively speaking). I wonder if the MMG W's could be used in a sealed box without much of a problem..
Old 25th August 2012, 02:47 AM   #56
Ah yes, that's a good point I had not considered yet. Maggies are tuned to be resonant at a certain point to maximize their low end output. Too small of an enclosure might accentuate that effect. OK, larger box that protrudes from the wall a bit and generous amounts of cotton to kill the back wave. That ought to do it. Let's add that killer IB sub I've always wanted too. Stereo line arrays of Dayton Reference sound good?
Old 25th August 2012, 06:19 PM   #57
Greg
Just found this..
Magnepan MMG Speaker System Measurements | Home Theater
Ouch! Actually, it would probably work perfectly in a sealed chamber(Or mounted on the wall by the supplied hinge). Also, the high's would be way more elevated at the actual listening distance. At one meter, they just don't have time to develop..
Old 26th August 2012, 12:16 AM   #58
Just found this..
Well, that looks downright scary at first glance, BUT if these were mounted in an enclosure, I think we would find that the midbass area of interest btw 100-500hz would come back up into line with the sensitivity of the rest of the range since there would be no more dipole roll-off. And we would be using multiple units which ought to couple their output and gain a little free lunch there too. I still think with good active DSP it is a serious possibility to create a butt-kicking, name-taking system based on this idea. Who's gonna pull the trigger? I'll offer friendly encouragement!
Greg
Old 26th August 2012, 07:41 PM   #59
Greg
Come to think of it, a single Neo 10 on the same sized panel as the mmg w, will have much better low frequency extension(-5db @ 130hz) much lower distortion(due to the balanced, symetrical motor arrangement), and a much higher efficiency than the MMG W, for only $75.00 more per pair(That's including baffles for the Neo 10's)..
http://www.zaphaudio.com/temp/B&G-Neo10-FR.gif
http://www.zaphaudio.com/temp/B&G-Neo10-HD-50-1.5k.gif
http://www.hometheater.com/content/m...m-measurements
Of course I'm using your Neo 10's(Measured by Zaph) to prove a point. (heh heh)
Old 26th August 2012, 08:13 PM   #60
Greg
Buzzkill!
Words best speaker?Hide this!Advertise here!
Too awesome for words abzug Tubes / Valves 35 22nd February 2012 10:48 PM
Is being able to 'Understand the words/vocals/lyrics' the sign of a great speaker ? 60ndown Full Range 10 16th June 2011 08:05 AM
The power of words Cal Weldon The Lounge 5 13th May 2011 08:34 AM
In few words Yvesm Tubes / Valves 4 1st June 2005 03:00 PM
Copyright ©1999-2017 diyAudio
