Planars & Exotics ESL's, planars, and alternative technologies
Goodbye ! No more speakers with cones !
Old 8th August 2012, 07:13 AM   #221
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
You are constantly trying to explain how a conventional cone speaker works. We know that already.
I thought this discussion was whether/how the planot driver works.
I'm with SY here: for the planot 'diaphragm' it's mass, stiffness, geometry.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 8th August 2012, 07:30 AM   #222
ziggyr is offline ziggyr
What about distributed modes, NXT etc. Surely Julian's prototype clearly shows that the Planot is nothing more than another form of NXT style speaker!!!!
When are you guys going to get it? There is no extraordinary invention or specialised physics at work here............it's simple excitation of a tube via a magnetic motor/voice coil.
Where does a conventional speaker get it's sound?..........from the vibrations generated from the voice coil.
Old 8th August 2012, 10:27 AM   #223
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Can you explain that simple what happens if at least half a pound of even distributed mass, at a varying distance from the neutral axis, is twisted (clockwise and counter clockwise) over a 48" length, at 10kHz and more ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 8th August 2012, 12:05 PM   #224
lcsaszar is offline lcsaszar  Hungary
But what I don't understand, how can a tube rotating around its axis generate any sound...
Old 8th August 2012, 01:49 PM   #225
You don't understand the sound of a hand waving ?
(with a little draft, even a rotating round tube could produce sound)
Old 8th August 2012, 02:16 PM   #226
On Hiatus
SY's Avatar
Doesn't even need a draft- there's drag at the surface. Damn inefficient, but nonzero.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th August 2012, 04:55 PM   #227
jan.didden's Avatar
Hah! Spin it fast enough and the air boundary layer will start to delaminate and you've got yourselve a nice sonic boom! That must surely qualify as 'generating sound'
jan
Old 9th August 2012, 01:29 AM   #228
I have already explained how the tube makes sound.
The rotation of the rod is a byproduct of the way it is attached to the motor and rotates left and right exactly as it does in a hard drive, but with homing magnets to control ''over rotation''..........a sort of brake system.
Everyone seems to be fixated by the ''rotation of the rod''. This is due to the clever marketing hype on the PLanot's website. It is NOT the rotation that is causing ''pressure waves'' or anything like that.That is ridiculous!
It is only the vibrations that are moving the rod and vibrations only that produce the sound.
Have a look at all those videos on youtube entitled ''hard drive loudspeakers''. It's the same thing.
As soon a something like a light plastic cup is glued on to the bearing arm of the hard drive the sound increases in volume.
You will also notice a side by side movement of the cups which includes lots of minor rotations that are more difficult to see as they are minute compared to the longer bass wavelengths.
Replace the cups with a vertical rod, supported at the top as well as the bottom and you have the Planot clone as demonstrated in Julians video.
Old 9th August 2012, 09:43 AM   #229
jan.didden's Avatar
Yet, reading the patent, to me it seems that the rotation causing pressure waves is what is patented. Did I misunderstand that?
jan
Old 9th August 2012, 10:13 AM   #230
On Hiatus
SY's Avatar
Jan: The claim reads:
A diaphragm for a rotary loudspeaker driver which radiates sound at all frequencies in its range in a 360 degree horizontal pattern and can function as a full-range driver or can be implemented as a limited frequency range driver and that eliminates phase cancellation (a) comprising the diaphragm structure with sides which have parallel and straight edges and the edges of each of these sides are parallel with the central axis of rotation, each of these sides being a simple rectangle, and the diaphragm's cross section has at least three equal sides and which is light and rigid (b) the diaphragm has a structure on both ends of its axis for attaching bearings and one or more electric motors to a rigid structure or frame (c) the diaphragm that has at least three sides and when rotated along its central axis creates a positive pressure in the surrounding medium on all sides parallel to the axis of rotation and is not subject to phase cancellation of front and back waves (d) the diaphragm in which the width of each side is equal to the width of the wavelength of the highest frequency that is to be radiated uniformly in the horizontal plane (e) whereby the diaphragm may radiate sound evenly at all frequencies within its range in a horizontal 360 degree pattern and vertically along its entire length. (italics mine- SY)
As a note, in order to infringe, ALL elements of the claim must be present.
Goodbye ! No more speakers with cones !Hide this!Advertise here!
damping coating substances for speakers' cones ? alan-1-b Multi-Way 35 7th May 2015 05:39 PM
Hello and Goodbye for a bit justblair Introductions 1 10th April 2009 02:28 AM
Acoustic Research Speakers - Cones and Covers storeyboy10 Multi-Way 1 5th July 2006 11:49 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 12:37 PM
Copyright ©1999-2017 diyAudio
