Planars & Exotics ESL's, planars, and alternative technologies
Goodbye ! No more speakers with cones !
Old 7th August 2012, 09:20 PM   #211
ondesx is offline ondesx  France
Originally Posted by SY View Post
If you take the assertion about tweeter inductance to its logical conclusion, a coil with perfectly conducting wire couldn't give you any HF output since it would be purely inductive.
If I'm correct, we are speaking here of a "Full-Range" driver ? Don't we ?
Old 7th August 2012, 09:24 PM   #212
On Hiatus
SY's Avatar
Regardless.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th August 2012, 09:32 PM   #213
Regardless.
Please, look at the impedance curve of several tweeters and several full-range... I don't understand what you try to prove.
Old 7th August 2012, 09:42 PM   #214
adason is offline adason  United States
adason's Avatar
I tried to unsubscribe from this thread, but it did not let me. I want to get out!
Goodbuy! No more!
Old 7th August 2012, 10:23 PM   #215
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by ondesx View Post
The complex impedance of a voice-coil have a value dependent of the DC resistance and of its inductance L. While the first is independant of the frequency, this is not the case of the later.
Yes this is true. And I am sure you can cite even more things that are true and that have no bearing on the physical issues that determine wheter this driver will 'work' or not.
Too bad, I thought you really had something there.
jan
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 7th August 2012, 11:37 PM   #216
On Hiatus
SY's Avatar
I've measured one or two over the years. The rise in impedance with rising frequency is generally not the cause of high frequency limitations, it's mass, stiffness, and geometry.
Old 8th August 2012, 12:09 AM   #217
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mixing up cause and effect is not uncommon.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 8th August 2012, 01:02 AM   #218
R.I.P.
My answer is the same that I wrote to SY... There are other similar
drivers suggested and built by guys who are sort of "genius" in the
area of professional audio...
Are you a genius in professional audio ?...
There has never been anyone remotely resembling a genius
regarding audio development and there never ever will be.
(Clever yes, genius no, why? You work out the inevitable.)
Some far sighted types like Blumlein pre WW2
but unfortunately he didn't survive WW2.
You are in no position whatsoever to define "genius".
Genius's don't ignore schoolboy physics, they redefine them.
I suspect your are a victim of believing marketing speak
"trash talking" and "revolutionary developments" without
having any real clue as to the real obfuscation involved.
No I'm not a "genius in professional audio" but i can
guarantee I know shedloads more about the subject
than you do, if your going to resort to the argument
you don't know much so neither does anyone else,
IMO you have no real idea of what is expertise
Believe the "hype" if you want and "believe" all engineers
are full of the proverbial regarding audio if you like, but
when push comes to shove who would you prefer to
service the brakes on your car, me or a "genius".
rgds, sreten.
Old 8th August 2012, 01:46 AM   #219
vacuphile is online now vacuphile  Netherlands
vacuphile's Avatar
Since the originator of this thread left, for me it is Goodbye! to Goodbye ! No more speakers with cones !
vac
But from now on I will be discrete about it.
Old 8th August 2012, 05:38 AM   #220
OK, this will be my last post on the present thread. Look SY, your statement is simply untrue. For the incidence of the mass on the response curve, please do a very simple experiment : take a full-range driver, measure its frequency-response.
Then firmly glue some mass on the durst cap, the double or even the triple of the membrane mass for example. Do again the measure of the response curve.
You'll verify by yourself that both curves are very similar. The big difference will be... the amplitude of the response, i. e. the power output, but not definitely the frequency response...
Good bye and good luck to every one.
Goodbye ! No more speakers with cones !Hide this!Advertise here!
damping coating substances for speakers' cones ? alan-1-b Multi-Way 35 7th May 2015 05:39 PM
Hello and Goodbye for a bit justblair Introductions 1 10th April 2009 02:28 AM
Acoustic Research Speakers - Cones and Covers storeyboy10 Multi-Way 1 5th July 2006 11:49 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 12:37 PM
Copyright ©1999-2017 diyAudio
