Planars & Exotics ESL's, planars, and alternative technologies
Goodbye ! No more speakers with cones !
Old 4th August 2012, 09:17 AM   #121
R.I.P.
Originally Posted by planot View Post
What do you mean when you say it doesn't work?
Quite simply :
if the diaphragm is made of unobtainium that is infinitely stiff,
rotation of the diaphragm will produce no bass whatsoever.
The claimed subwoofer applications for the operating principle, e.g. :
simply will not work. There is nothing to discuss about the basic
physics in the bass, it is not a voltage to pressure transducer.
There is nothing here that reduces the need for boxes for bass.
rgds, sreten.
(I never said it won't make some noise, it will, but I'm not
interested in something so fundamentally misrepresented.)
Old 4th August 2012, 09:59 AM   #122
Remlab is offline Remlab  United States
Originally Posted by ondesx View Post
That's precisely what I would check with this device... The best thing you can do to better understand the bending waves transducers like the Walsh or the DDD is to read the Walsh patent available as a pdf on the Net. If you fail to find it, I can give you its reference.
It seems you're in California. Do you had listen to one of the MAD drivers ?
Mad? As in Dragoslav Colich? He lives and works a couple of miles from my home but I have never heard his designs. He now owns a consulting business in Irvine.
If you have seen my speaker system on this website, you will see that I'm a big fan of BG Radia Planar Magnetic drive units. The Mad designs look cosmetically very similar.
As far as the DDD and Walsh drivers go, I understand that they operate in a pistonic manner up to a point, then will start to bend at a critical frequency. Correct? Jordan controflex cones are somewhat similar? There just seems to be an element of chaos involved that the best math can't overcome..
Old 4th August 2012, 10:23 AM   #123
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The DDD does not work pistonic but produces 'bending waves' that ripple from the voice coil through the material to the surround where they are absorbed. The bending wave causes sound to radiate radially in a horizontal plane.
The DDD looks superfically like a cone pointing downwards, but it is not a piston. The flare and angle is more like a mildly flaring cone than a piston in shape.
jan didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 4th August 2012, 10:32 AM   #124
jan didden
Read this..
German Physiks - High End Technology Loudspeaker Manufactur - DDD Driver - The DDD Driver
Jordan cones are sort of like a DDD cone, but used conventionally. At a certain critical frequency, they start to bend and produce the higher frequencies in a somewhat even manner, instead of a rigid cone that has one big resonant peak..
Old 4th August 2012, 10:51 AM   #125
R.I.P.
The DDD driver inherently must have a pistonic region of operation at the low end.
rgds, sreten.
Old 4th August 2012, 11:29 AM   #126
ondesx is offline ondesx  France
Yes, this is the driver I mentioned... Unfortunately, this guy never answers my request for a couple of this planar driver... The radia BG are unfortunatey poorly manufactured and you can easily spin the driver on his axis, this gives you an idea of its rigidity. If you have the opportunity to listen or try the MAD please let me know your feelings...
It's correct that the Walsh and the DDD have both a pistonic "range"... Then this is another difference with NXT/BMR drivers !...
Old 4th August 2012, 12:46 PM   #127
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The issue is the spining frequency in clockwise and cc at very high frequencies taking into account the inertial moment of the device, moreover with an excitation at one end only... The torque will probably have severe consequences on the "membrane" each time the actuator changes its spining direction!
Maybe a nice subwoofer, if it's huge enough.
(damn, i already have a set of pivoting transducers and didn't know, only requires to raise the frequency setting Quantum Stabilizers- Lambert Dinnissen explains rotary yacht stabilizers - YouTube )
Old 4th August 2012, 01:13 PM   #128
Since a simple and thin chord is able to deliver a sound like on a violin or a guitar, why a thin and light diaphragm wouldn't have a similar action ?... The unknow remains the high frequency cut-off of the system : if the actuator isn't correctly dimensioned, the diaphragm will stop its spining at a given frequency, then the system behaves like a low-pass filter !
Old 4th August 2012, 01:53 PM   #129
jan.didden's Avatar
Yes that may be the case here - that it delivers a specific tone, with some overtones, but not a full spectrum.
jan
Old 4th August 2012, 02:08 PM   #130
jan
Are you sure of this statement ?... I definitely will give a try before any conclusion...
Goodbye ! No more speakers with cones !Hide this!Advertise here!
damping coating substances for speakers' cones ? alan-1-b Multi-Way 35 7th May 2015 04:39 PM
Hello and Goodbye for a bit justblair Introductions 1 10th April 2009 01:28 AM
Acoustic Research Speakers - Cones and Covers storeyboy10 Multi-Way 1 5th July 2006 10:49 PM
Plastic cones or paper cones? beppe61 Multi-Way 19 19th February 2006 11:37 AM
