Planars & Exotics ESL's, planars, and alternative technologies
Planar magnetic/ESL/ribbon thermal compression
Old 18th June 2012, 05:47 PM   #1
Dan_E10 is offline Dan_E10  United States
Default Planar magnetic/ESL/ribbon thermal compression
I assumed that for listening in a home environment, even at high levels (avg. 90 db) that thermal compression would be a complete nonissue for any of the panel speaker technologies. I was a bit surprised when I came across Linkwitz's tests of a BG Radia Neo3 vs. a Seas 1" dome: Spatial distortion
which according to Linkwitz shows some thermal compression effects for the NEO3 that are not apparent for the 1" dome. Granted, I've seen criticism that no one in there right mind would use a NEO3 the way he tested it, but regardless I would have expected the NEO3 to have less thermal compression at high levels than a 1" dome. I'm wondering in a larger well constructed Magnepan style speaker or alternatively a hybrid ESL, can thermal effects be ignored even at 90+db listening levels? I realize this will depend on a lot of factors but primarily I'm interested in ~100 Hz on up with panels size allowed to be similar or slightly larger than used in Magnepan's models. Part of my motivation is looking at mixing and matching the different technologies in a single speaker, for example magnetic planar bass panel with ESL midrange and either ribbon or narrow ESL tweeter segment.
I should probably also specify that I'm looking for good output above 100 Hz because I use an array of 3 subs spaced around the room a la Geddes for the sub 100 Hz region.
Dan
Old 18th June 2012, 11:40 PM   #2
JAMESBOS is offline JAMESBOS  England
Default FULL RANGE PLANARS.
I have built about 30 full range planars and never had any trouble with heat problems. Fom A4 size to 7' x 2' using ferrites and neo magnets.
HENRY
Planar magnetic/ESL/ribbon thermal compressionHide this!Advertise here!
help designing a magnetic planar woofer baffleman Planars & Exotics 14 18th April 2014 04:01 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 01:48 PM
Mini planar magnetic using neos karellen Planars & Exotics 83 3rd April 2012 02:02 AM
Planar Magnetic Drivers - 8" rubicon Swap Meet 8 1st December 2010 07:22 PM
ESL vs Planar Magnetic Borat Planars & Exotics 40 8th September 2009 02:47 PM
Copyright ©1999-2017 diyAudio
