Planars & Exotics ESL's, planars, and alternative technologies
Mylar tension on Sequel II
Old 12th June 2012, 01:13 PM   #1
peregrin288 is offline peregrin288  United States
Default Mylar tension on Sequel II
Hello all,
I am reconditioning a pair of Martin Logan Sequel IIs. I am at the point where I need to stretch the 6 micron film. Does anybody know what the tension should be for the curved panels? I have seen similar curved stator designs with a tension of 2.5kg. Is this correct?
Thanks for any and all help.
Kris
Old 14th June 2012, 03:31 PM   #2
stokessd is offline stokessd  United States
stokessd's Avatar
Have you already removed the original diaphragms? If not, I'd measure the tension on them before disassembly.
With curved panels, you'll want to tension in the non-curved dimension, with only minimal tension in the curved dimension (just to remove any wrinkles).
Sheldon
Old 14th June 2012, 05:39 PM   #3
Sheldon, thanks for the reply.
The original diaphragms were torn and wrinkled, so there wasn't any way for me to measure without tearing the mylar more. I had heard the same advice about tensioning in the non-curved direction, and only pulling a little in the other direction to get whatever wrinkles out that still happen to be there.
I guess I'll have to try 2.5kg and see what happens.
Old 14th June 2012, 11:25 PM   #4
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
You can do another trick posted here long time ago. First the diaphragm is stretched just to be free of wrinkles. Then place two dots with a marker lets say 200 mm apart. It needs to be stretched to around 2%(so to 204mm).
I may be wrong but I highly doubt 2.5 kg will be enough(I you are talking about total longitudinal tension). Maybe ten times that... I have had wooden frames(made from 50x50mm material) bending significantly when 2% target is reached, and that with 2 um film.
Old 15th June 2012, 12:27 PM   #5
Thanks for the info, Bazukaz.
2.5kg was definitely not enough. 4kg worked very well though. I finished the mylar on one panel last night, hoping to do the other today.
I'll post pics of the stretching and mounting jig when I get a chance.
Old 15th June 2012, 01:13 PM   #6
tyu is offline tyu  United States
Where did you get your mylar?
DId you strip all the back of the dobbel sided tape an put down all new tape?
what did you use at the top an bottem?
what coting well you be using?
I have ML SL3 Like yours panels i need to do the same thing too...Thanks for any info
Old 15th June 2012, 06:14 PM   #7
Hi tyu,
I stripped everything off the stator and reapplied double-sided foam tape. One strip on the sides, two on the top and bottom.
For supplies and other ideas, see this site:
Jazzman's DIY Electrostatic Loudspeaker Page
There are links to coatings, 3M tape, mylar on eBay, assembly ideas, etc.
This page shows a curved stator like ML, but he attaches the mylar to the back of the front stator. I built a similar tensioning jig and used it upside down. As soon as I find my camera, I'll post pics. He also says he tensions his mylar to 2.5kgs, but I found that I needed 4kgs.
https://sites.google.com/site/eslarr...chingandgluing
I hope this helps.
Old 15th June 2012, 09:18 PM   #8
Default Bias feeds althe way around would be best!
You may have alredy don this but....I have also here a pr of Acsent an Prodigys...an i have pop the panels apart...lot ezer to do this with the newer ML panels than the older ones like 2001 on...without riping the mylar...an ran a bias strip up the left an right sides of the panels..this give more output to the panels an thay sound much better...ML only runs up the right side ...got too sale panels...it $ 1k for the SL3s now..here some pic you may have seen of the ML guy working on there jig...thanks
Mylar tension on Sequel IIHide this!Advertise here!
A Grounding Mod for Sequel II Rob in Montana Planars & Exotics 4 15th April 2012 11:29 PM
Another Sequel II Mod Rob in Montana Planars & Exotics 6 7th January 2012 12:40 PM
ESL Mylar stretching Tension Arno Pf Planars & Exotics 2 2nd May 2011 11:28 AM
Martin Logan Sequel II - $550 mbcouple Swap Meet 18 13th April 2011 03:38 AM
ML Sequel II Michael Wiest Planars & Exotics 1 23rd January 2005 07:49 AM
