Planars & Exotics ESL's, planars, and alternative technologies
DIY 4 Inch Ribbon Tweeter
Old 5th May 2012, 09:40 PM   #1
fooeywuffle is offline fooeywuffle  United States
fooeywuffle's Avatar
Default DIY 4 Inch Ribbon Tweeter
Here is info on the tweeter I made. It has 4 5/16 inch long magnetic part and ribbon is 3/8 inch wide. .03 ohms for pleated ribbon. This is quite a project to make the parts. A lot of cutting, filing, drilling, and tapping. The 1/2 X 1/2 X 2 inch magnets are the N52 which is the strongest I could find. Since it is high current, the wires are large and soldered into deep holes in the brass part. Top part is thick so will press on ribbon evenly. One end is insulated from steel part. When done and has a good ribbon, will have an aluminum screen cover. So far testing things, I have destroyed 3 ribbons. One to measure the resistance, one when I hooked it to transformer at full volume, that was ear splitting! One jusr wasn't right, so rubbed. Hard to get one straight. I don't know if kitchen foil is really any good for this. Seems stuff a little tempered would work better.
Old 5th May 2012, 11:47 PM   #2
LineSource is offline LineSource  United States
LineSource's Avatar
Heavy Metal!
Monster Magnets!
You da'MAN!
Here is what I have learned:
1) Your ribbon has extra pole metal that will hurt efficiency. Steel/Iron saturates ~ 1.5Tesla, so the highest gap flux comes from having just the monster NdFeB magnets next to the ribbon in the gap, and attached directly to the large steel/iron pole pieces, held with either super-duper glue or AL-sheet clamps. Putting steel/iron poles next to the ribbon will reduce the max Telsa flux when super magnets are used.
2) For the optimum uniform gap magnetic field, you either want to use non-magnetic spacer(ribbon_clamp) materials like aluminum, or put several thin steel/iron spacers at the top, bottom, 0.25x, 0.5x, 0.75x positions. The steel spacers can be thin but deep for extra volume.
3) Household AL-foil is typically between 12.5u and 25u-meters thick. Any pure Al true-ribbon foil above ~6 microns "sizzles" to my ears when used in a tweeter. My tweeters use 5.4um pure aluminum foil, and this thickness is soft enough to dampen any "sizzle". SHAKE-SHAKE-SHAKE your ribbon AL foil and listen for "sizzle". Some very thin AL-ribbon tweeters, like the 2um Magnepan, use AL Alloy 5056 for higher strength and 2x higher resistance/square. High failure rates are common with <5um AL foil.
4) Several modern tweeters like the RAAL "emboss" the AL foil instead of corrugating it. This both reduces the weight, and keeps the ribbon motion more planar with just suspension at the ends. RAAL uses heat-shrink mylar at the top-bottom of the embossed ribbon attachment as a suspension. RAAL keeps the ribbon height to a minumum by using the thin PCB copper for the ribbon attachment.
5) There are a few very good threads on multi-filiment wire step-up transformer winding. Toroid, and stacked-foil C_cores from AMCC are often used.
6) A ribbon is very sonically-transparent of any rear reflections, so extensive rear dampening material (wool, fiberglass) is often used behind monpole ribbons.
Old 6th May 2012, 05:31 PM   #3
So, I should remove the iron parts, and make a wider ribbon. Ideally, replace the magnets with ones 1/2 X 5/8 inch and use the same size ribbon. They are so strong, no glue needed, just brass pegs in the iron so they don't tend to go all the way to the back.
I have a way to emboss it, so will try that also. I prefer the end clamps for the ribbon. harder to make, but very easy to replace a ruined ribbon.
One of the threads is mine on transformer winding. I have been doing it for 40 years, so know how to wind all kinds. For this I found that Ferrite is the only good core, the rest are too expensive for me to try, or are just too lossy. For this, RF type transformer works best. Basically flattened tube with the primary inside.
Yes, I was going to put dampening stuff in it when completed.
Old 7th May 2012, 12:28 AM   #4
LineSource's Avatar
MAXIMUM FLUX: For a monopole ribbon tweeter the commercially successful RAAL uses a 3-sided fully enclosed steel magnetic circuit to get the highest flux in the gap. Extensive absorption material and clever partitioning of the cavity to shorter than a wavelength widths are necessary to reduce resonances and rear ribbon reflections. To get the maximum gap flux some DIY'ers go so far as to use 1" x 3" steel for the sides and rear - very heavy metal.
MINIMUM REAR CAVITY EFFECTS: To minimize rear cavity reflections to the back of the ribbon, as well as minimize cavity resonances, some monopole ribbons are constructed with just N+S pole steel as might be done for a dipole ribbon. Extensive dampening material is still used behind the ribbon, but with fewer volume restrictions. Some pole cavity partitioning can help raise resonance frequencies. A few thin rear steel cross braces can increase the gap flux with a modest sonic signature.
Successful integration of the tweeter ribbon with the midrange will set limits in height, lowest frequency of operation, and maximum SPL. The center-to-center distance will determine the required crossover frequency to minimize lobing. The idea is to keep C-to-C below 1/4 of the crossover frequency wavelength, but 1/2 wavelength is often accepted as the longest compromise. The ribbon's highest frequency will set the optimal ribbon width. The required SPL will set ribbon area = height * width. RAAL's new 70x20 short-and-wide ribbon is starting to become popular because it gives up some of the highest frequency extension to keep a modest physical height to control T-M lobing.
Old 7th May 2012, 01:19 AM   #5
Remlab is offline Remlab  United States
Here is a company that sells small quantity orders of aluminum, steel and other types of metals of all shapes and sizes that you could and should take advantage of..
Online Metal Store | Small Quantity Metal Orders | Metal Cutting, Sales & Shipping | Buy Steel, Aluminum, Copper, Brass, Stainless | Metal Product Guides at OnlineMetals.com
Old 7th May 2012, 05:51 AM   #6
LineSource's Avatar
I sketched a few tweeter ribbon top view construction ideas for brain trust discussions. I use the open back design with 0.5" x 0.5" N50 NdFeB magnets on 0.5" x 0.5" steel pole pieces since I can use it as either a monopole with rear stuffing or as a dipole without stuffing. Lately I've been using 0.7" and 1" wide 5.4um and 8um embossed aluminum foil ribbons to push down the safe LR4 crossover frequency close to 1.1Khz at the expense of some high frequency beaming because I favor using a 7"-10" midbass to cover 100-1200Hz.
MY FAVORITE PHOTOSHOP RIBBON SPEAKER: If you ever sketch up a few 3-way cabinets using your ribbon tweeter a shape like the Avalon Isis might be worth consideration. Olson's early research into cabinet diffraction motivated speaker companies like Avalon to evolve a version of the truncated pyramid on parallelopiped baffle shape. Reduces diffraction, looks sexy(abstract Chess Bishop), easier to build than a sphere. The Isis uses a very expensive 7" midrange, but there are modest cost 7"-8" midranges with 94-96 db/watt efficiency that can approach the ribbon efficiency without beaming at ~1.2KHz - 1.4Khz LR4 Xover.
Old 7th May 2012, 07:08 AM   #7
hunter audio is offline hunter audio  India
Very interesting thread , line source s experience very informative all our tries to even repair Japanese ribbon tweeters mostly resulted in smoke in a short while .
suranjan dasgupta
Old 3rd July 2015, 05:34 PM   #8
Default Ribbon Tweeters FINALLY Finished
I finally finished the 4 inch ribbon tweeters. I figure 4 of them is enough! They were a lot of work to make look good. They are over twice as loud as any tweeter I have bought and a lot clearer.
Ray
____________________________________________
If brute force doesn't work, your not using enough of it!
Old 25th July 2015, 12:01 PM   #9
jegjessing is offline jegjessing  Denmark
Default What about driving?
Does this ribbon not have an extremely low impedance?
Do you use an impedance converter? And if so, what?
Old 26th July 2015, 11:59 PM   #10
Default Low Impedance to 8 Ohm
Yes, .027 ohm. Transformer on back is 18 to 1. It is basically primary inside of a copper tube. Idea is used for wideband high power RF amplifiers and works very well for this also. I have many photo's of one being made. Not an easy project.
DIY 4 Inch Ribbon TweeterHide this!Advertise here!
DIY ribbon info requested (constructing a ribbon unit) SpinMonster Planars & Exotics 15 11th April 2011 09:27 PM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 09:50 AM
diy ribbon tweeter project paulfk Full Range 1 24th October 2008 03:51 PM
Diy Ribbon Tweeter For ESL PANNEL. pmscompany Planars & Exotics 10 1st July 2006 04:15 PM
Advice for DIY ribbon tweeter construction. Puggie Planars & Exotics 3 5th May 2006 06:53 PM
Copyright ©1999-2017 diyAudio
