Planars & Exotics ESL's, planars, and alternative technologies
Electrostatic Speaker Help/Trouble
Old 14th August 2012, 06:57 PM   #51
AndreaT is offline AndreaT  Italy
Default Bad news! After 2 more days drying-up the bad ES panel got back 5dB lower sensitivity
Hello Worl,
I am going to be crazy...
This is what happened after the 2 washing of my "bad" ES panel:
- After 1 day (24 h) of dry-up I got a sensitivy unbalance within 2dB (see my previous post)
- Today, after 2 more days of dry-up I got a very bad 5dB sensitivity unbalance, as better described in the below measurement graph
The green line at the bottom is the math "good panel sensitivity / bad panel sensitivity", so it is the net unbalance gap.
I really do not understand how this panel worked better when still a bit humit, while getting dryed is working progressively worse.
Anyone has an idea about this very strange behavior?
Many thanks and, again, kind regards,
Andrea
Old 14th August 2012, 07:33 PM   #52
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Would this behavior be explained by having an unreliable connection between the diaphragm and the copper strip that runs along the side? Better connection when damp; poorer when dry? If so, adding clamping pressure might help....
Old 15th August 2012, 03:08 AM   #53
CharlieM is offline CharlieM  United States
CharlieM's Avatar
All else being equal, I figure you either have an unreliable diaphragm-to-bias supply connection or it's time to re-coat the diaphragms.
Old 15th August 2012, 06:39 PM   #54
Thanks Andersonix and ChalieM for your suggestions.
I will follow both.
I am sure it is not a problem of connections or of the high voltage power supply (already checked twice).
Regards, Andrea
Old 16th August 2012, 12:51 PM   #55
Default Needing instruction to open the ML ES panel
Hello Friends,
I would re-coat my old Sequel II ES panel, so I need to open my Martin Logan Sequel II panels.
Anybody out there is willing to give me precise instruction to correctly separate the back stator from the front stator without tearing the diaphragm film?
I never did it before and I have fear to damage something.
Many thanks in advance!
Kind regards,
Andrea
Old 1st September 2012, 08:25 PM   #56
john65b is offline john65b  United States
john65b's Avatar
I have similar problem on my single CLS panel I washed/opened up/recoated. I now have a leak from mylar to back stator.
I still think there is moisture in foam tape allowing leak of charge, making the panel less efficient.
After playing, unplug the I/F from amp and power, and short the bias on mylar to the stator. See if you get a nice sharp spark. Do teh sameon other panel.
On my CLS, I see /hear a nice sharp spark on unwashed panel ,while on the washed panel that I have a 6db difference, I barely see / hear a spark. This is confirmed by my Neon Bias Charge indicator.
Still think the moisture is leaking charge, so I am going to wait a week to better dry before trying anything new...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Electrostatic Speaker Help/TroubleHide this!Advertise here!
Building an Electrostatic Speaker Atom66 Planars & Exotics 21 1st June 2011 03:16 PM
Electrostatic speaker DIY from Metaxas peranders Multi-Way 3 23rd November 2008 11:49 PM
Anyone heard of a KEF electrostatic speaker ? RobWells Planars & Exotics 11 17th December 2006 12:39 PM
Electrostatic Speaker Kit up on ebay mikejz84 Planars & Exotics 3 19th October 2003 01:53 AM
Beginner Electrostatic Speaker BennySP Planars & Exotics 11 2nd June 2002 06:37 AM
Copyright ©1999-2017 diyAudio
