Planars & Exotics ESL's, planars, and alternative technologies
Bg Neo 10 and Neo 8
Bg Neo 10 and Neo 8
Old 3rd July 2012, 03:00 PM   #231
boris81 is offline boris81  United States
Default VSS5 F3 @ 21Hz
F3 @ 21Hz will be challenging to achieve with a ported design even with 3 woofers.
I would guess that the dipole peak of the baffle and the wings is around 200Hz.
Because of the dipole roll-off the response at 21Hz will be -24dB.
Each extra woofer adds +3dB and let's add another +3dB for F3 so then the woofers need to be 24-(3+3+3) = 15dB more efficient than the midrange.
The Neo10 sensitivity is about 90dB so the woofers' sensitivity should be at least 105dB.
So far so good except all woofers with that kind of sensitivity begin roll-off in free air around 80Hz or higher. Am I missing something?
Old 3rd July 2012, 11:19 PM   #232
Remlab is offline Remlab  United States
Jamo did it..
Jamo Reference R 907 loudspeaker Measurements | Stereophile.com
Old 4th July 2012, 06:57 AM   #233
StigErik is offline StigErik  Norway
StigErik's Avatar
Originally Posted by studiotech View Post
Uh huh, sure. Let's see those measurements. Don't think we will. I am developing a love/hate feeling for these speakers.
Verified measurements of the VSS5
Those specs are just too good to be true, and they can't be true for a various number of reasons.
This reminds me of an other guy in Norway that claimed flat response to 8 Hz with three 8" in a very small open baffle. And of course 100 dB sensitivity. That like claiming a VW beetle can do 0-100 km/h in 0,07 seconds.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 4th July 2012, 07:02 AM   #234
StigErik's Avatar
I have 20 Hz response with my own dipole system. But to achive audible SPL with acceptable levels of distortion, that required 16 (sixteen) 21" woofers in very large H-baffles. And 30 dB of EQ.
Anyone claiming 20 Hz with a dipole of that size as the VSS5 is simply lying.
Old 4th July 2012, 03:46 PM   #235
StigEric
Can you show us pic's of your dipole speakers please (In room)? Speakers that size would severely limit room placement options. When it comes to dipoles producing 20 hz, placement and room size is EVERYTHING.
Seth
Old 4th July 2012, 03:57 PM   #236
StigErik's Avatar
There is a looong thread on this forum....
Start here:
http://www.diyaudio.com/forums/multi...ml#post2922246
Old 4th July 2012, 04:16 PM   #237
Start here:
Thank you. Wow! Amazing system! Humbling..
Now, the next question begs to be asked. How can Jamo hit 20hz (-6db) in room with just two 12" drivers per side.
Old 4th July 2012, 08:53 PM   #238
StigErik's Avatar
Any LF extension is possible with enough EQ, be it passive or active. But do you think the Jamo can reproduce 20 Hz loud enough for anyone to hear it? And how much distortion is there at 20 Hz...? My guess is that is can play something like 80 dB at 20 Hz before distortion skyrockets, which is barely audible. And when we consider that the ear's sensitivity at the 2nd and 3rd harmonic is tenths of dB greater than the fundamental, all we will hear is distortion when the driver is getting close to Xmax.
Old 5th July 2012, 02:52 AM   #239
I have to admit that, compared to your system, probably everything on the planet falls short. But as far as in room 25 hz (-3DB)measurements are concerned, It is pulling off the trick. The other speaker mentioned could be doing the same. Distortion and dynamic capability? Obviously can't be very good. Relatively speaking of course..
Old 5th July 2012, 06:36 AM   #240
StigErik's Avatar
A speaker that measures flat in-room will sound somewhat thin or bright. A curve that slopes down about 10 dB from 20 Hz sound more natural.... so the Jamo is still missing almost 10 dB @ 25 Hz. Toole (at Harman) did some listening tests about this, I shall try to find it.
Bg Neo 10 and Neo 8Hide this!Advertise here!
F/S (3) BG NEO:10 Planar Magnetic Panels rubicon Vendor's Bazaar 1 31st December 2011 05:39 PM
BG Neo 10 (Neo10) vs. Alcons RB401, SA8535, ESS AMT, or Beyma's TPL-150 tiefbassuebertr Multi-Way 1 6th December 2011 12:54 AM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 06:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 05:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 09:00 AM
Copyright ©1999-2017 diyAudio
