Planars & Exotics ESL's, planars, and alternative technologies
Bg Neo 10 and Neo 8
Bg Neo 10 and Neo 8
Old 22nd April 2012, 04:18 PM   #151
natehansen66 is offline natehansen66  United States
Originally Posted by studiotech View Post
I wondered about the same thing, BUT Dennis is using the regular noe8 with no issues...
We will find out soon enough.
Greg
Are you talking about the Philharmonic line? I'm pretty sure the Neo8 cab is open backed and stuffed.......
Originally Posted by Toaster View Post
I keep forgetting that I've got four of the standard Neo 8 to try!
Get to it! I just got some regular Neo8's and I love them. Better than the few cone drivers I've tired . They do quite well from 900-4500......
Old 22nd April 2012, 10:48 PM   #152
Remlab is offline Remlab  United States
If he tested the 8-s in the exact same open backed and stuffed philharmonic cabinet that uses for the 8, which would make sense, then it would or could point to a potential flaw in the 8-s. Hmm... Your results will be interesting, Greg.
Old 23rd April 2012, 03:51 PM   #153
Toaster is offline Toaster  United Kingdom
It would be surprising if there was such an obvious flaw in the design of the unit given the measurements of the standard '8 and the '10, but it's possible of course.
Old 29th April 2012, 12:42 AM   #154
O.K. I found the headphones I'm going to use for the Neo 3's. They are amazing can's for the money. Sturdily built, two detachable cords of different lengths(11.5ft and 4ft),and two swivel points(Three if you include the fold up feature). All this for $22.00. They supposedly sound amazing. They are the Mono Price's at the bottom of this page
InnerFidelity's "Wall of Fame" Full-Size Sealed | InnerFidelity
I'm taking the drivers out and replacing them with the neo 3's. I am also removing the closed back from these can's because planar magnetic headphones sound much better that way. Planar magnetic headphones are amazingly expensive( $700.00 up to $2,000). If this experiment works, they can be had for under $200.00. If they sound good enough to my ears, I'll send them to Tyll Herstens for a full battery of dummy head measurements which he then posts on his site in the DIY section..
Seth
Old 29th April 2012, 01:21 AM   #155
Seth
I'm starting a new thread for this project for obvious reasons..
Old 29th April 2012, 03:33 AM   #156
boris81 is offline boris81  United States
Default Neo8 on a waveguide
I'd like to experiment with a waveguide for the Neo8 in order to improve directivity in the highs. I've been waiting for more info on the Neo8-S before spending any money.
"Patric Bateman", another member of diyAudio got very promising results with a cone driver.
fauxaxial unity horn.mp4 - YouTube
thread: Suitable midrange cone, for bandpass mid in Unity horn.
Old 29th April 2012, 04:05 PM   #157
Remlab, even used at low levels as earspeakers, surely the high fs of the Neo 3s will make them unsuitable for full range use?
Old 29th April 2012, 08:39 PM   #158
Pinco Pallino is offline Pinco Pallino  Italy
Hi All! I am new to the community although being an oldtimer who has built speakers for more decades than I dare to count. I am impressed with the technical level of your posts. Please allow me to contribute my five pence.
I have used stacked NEO8 (old model) mids for several years without much satisfaction. I found the sound rather coarse. Recently, however, I took four NEO8 and used them as two sandwiched pairs, one pair for each speaker. I took a quarter inch board and fixed one Neo8 from the outside and the other one on the inside of the baffle. The space between the speakers I filled with a quarter inch sheet of foam to tame undesirable reflections. The size of the sealed enclosure is about 5 litres, stuffed with acrylic fibre. The speakers are wired in parallel.
With a suitable crossover or DSP equalization, the double Neo8 offers more lower mids and seems to me less brittle and coarse than a single one. In fact, after careful fine tuning with the DEQ I felt like being fairly close to electrostat levels. Still, the speakers (combined with a woofer and a Fountek ribbon) don't show that "silky" smoothness only 'stats can offer, IMO. I have not done any distortion measurements of the Neo8 combo.
Old 29th April 2012, 09:49 PM   #159
Toaster
The Neo 3 has no fs. For proof of this, look at the impedance trace on the Zaph website. Perfectly resistive(Flat) to the upper and lower limits of the graph. This is why planar magnetic tweeters can be used as headphone diaphrams, and conventional tweeters obviously cannot.
Seth
Old 29th April 2012, 10:26 PM   #160
If you want to create a more fair ESL, Neo 8comparison, try eliminating the fountek ribbon from the equation and dsp the Neo 8 by itself. The problem with the Neo 8 though, is that even used in this way, still can't go low enough to get the crossover point completely out of the critical midrange. This is why I went with the NEO 10 instead of the the 8.
Bg Neo 10 and Neo 8Hide this!Advertise here!
F/S (3) BG NEO:10 Planar Magnetic Panels rubicon Vendor's Bazaar 1 31st December 2011 05:39 PM
BG Neo 10 (Neo10) vs. Alcons RB401, SA8535, ESS AMT, or Beyma's TPL-150 tiefbassuebertr Multi-Way 1 6th December 2011 12:54 AM
BG NEO 10 pair as new inertial Swap Meet 20 31st January 2009 06:20 PM
Bg neo 10 measured inertial Multi-Way 12 7th October 2008 05:42 PM
BG neo 10 measured inertial Planars & Exotics 0 30th September 2008 09:00 AM
Copyright ©1999-2017 diyAudio
