Planars & Exotics ESL's, planars, and alternative technologies
Mini planar magnetic using neos
Old 12th January 2012, 10:59 AM   #1
karellen is offline karellen  Spain
Default Mini planar magnetic using neos
Hi everybody
I will try to make a mini planars for computer use.
the idea is to make a prototype for evaluation, an then a workable pair.
For now I have the frame and the foil, the magnets will arrive within a week.
however there are some problems to be solved, the first one is the low resistance of the foil; the first measure is 0,6 Ohms, bad thing.
The posible solutions are using a foil of 0,3 mm wide instead the actual 0,5 mm. this probably rise the impedance to 1 Ohm.
Another solution is doubling the length by replicating the pattern on the other side of the membrane, i.e. making a doble layer membrane, with a expected total resistance of 2 Ohms. This will be fine for the amplifier, with the addition of a series resistance of say 2 Ohms.
the active surface of the membrane is 10x18 Cm
What do you think?
Any help is welcome
Pedro
A cold amp is a sad amp... I like them warm at least
Old 12th January 2012, 02:14 PM   #2
JAMESBOS is offline JAMESBOS  England
I would use the epsilon layout which increases the length of the foil it also increases the sensitivity significantly. I wouldn't do a push pull design, I have tried several but there is no significant increase in sensitivity compared to the epsilon layout!!
HENRY
Old 12th January 2012, 02:31 PM   #3
lcsaszar is online now lcsaszar  Hungary
You can use an impedance matching transformer.
BTW I have seen a planar PC loudspeaker, same size as a normal PC speaker (except it is flat).
Old 12th January 2012, 02:47 PM   #4
Or you can use a resistor!
HENRY
Old 12th January 2012, 05:31 PM   #5
Originally Posted by karellen View Post
Hi everybody
What do you think?
Any help is welcome
Pedro
Hi Henry
I'm not thinking on a push pull arrangement, but on puting aluminium foil on both sides of the membrane.
Does anybody have tried this?
And about the resistor... Which value?
An 3 Ohm resistor will eat almost all the voltage, I suposse...
Old 12th January 2012, 05:40 PM   #6
Default Hi Oshifis
Where can I find a matching trafo?
Old 12th January 2012, 05:45 PM   #7
The epsilon layout seems very interesting.
The magnets are too slim, thought, so lets see
Thanks for the help
Old 12th January 2012, 10:39 PM   #8
Hi Henry
I wouldn't put foil on both sides of the membrane, this will double the weight and make it less sensitive! The resistor depends on the resistance of the foil and whether you want a 4 ohm,8 ohm or 16 ohm to go with your amplifier. The resistor hardly has a effect on the sensitivity.
HENRY
Old 12th January 2012, 10:46 PM   #9
Thanks for the help
The epsilon layout is the best I speak from experience as I have been building planars for over 20 years.The magnets can be the size you require you lay out the foil to fit the magnet sizes.
HENRY
Old 12th January 2012, 10:48 PM   #10
Hi everybody
What do you think?
Any help is welcome
Pedro
using this layout you won't get much sound.THE EPSILON LAYOUT IS A MUST.
HENRY
Mini planar magnetic using neosHide this!Advertise here!
Planar magnetic with central tweeter? Few Planars & Exotics 103 22nd March 2016 02:17 PM
help designing a magnetic planar woofer baffleman Planars & Exotics 14 18th April 2014 05:01 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 02:48 PM
Planar Magnetic Drivers - 8" rubicon Swap Meet 8 1st December 2010 08:22 PM
ESL vs Planar Magnetic Borat Planars & Exotics 40 8th September 2009 03:47 PM
Copyright ©1999-2017 diyAudio
