Planars & Exotics ESL's, planars, and alternative technologies
Mini planar magnetic using neos
Old 16th January 2012, 01:59 PM   #21
karellen is offline karellen  Spain
Default The magnets are here
The magnets arrived today
They are very nice!
I've broken a pair just sorting the lot, very fragile
The pics later; this ipad is nice, but has limitations on posting pics
The experiments are scheduled for tomorrow, wife allowing
A cold amp is a sad amp... I like them warm at least
Old 16th January 2012, 05:33 PM   #22
Default Optimization of magnetic field
Hi
I'm trying to optimize the limited number of magnets on existence.
there are three main configurations possible, A, B and C
Anybody can tell which has the better field?
I'm pairing the magnets in order to get an workable Epsilon layout.
in any case, the gap should be 1 Cm for practical matters, mainly a decent membrane surface, about 13X16 Cm
The available magnets are 90 units per speaker.
Thanks on advance
Any advice is welcome
the magnets are these: supermagnete - Q-20-04-02-N: Bloque magnético 20*x*4*x*2*mm
Bloque magnético
Cód. artículo: Q-20-04-02-N
Material: NdFeB
Forma: Bloque
Tamaño: 20 x 4 x 2 mm
Tolerancia: +/- 0,1 mm
Peso: 1,2 g
Recubrimiento: Niquelado (Ni-Cu-Ni)
Magnetización: N45
Fza. sujec.: aprox. 1,2 kg
Temperatura máxima de empleo: 80°C
Ficha técnica en PDF
20 mm4 mm2 mm
Imanes (N45) extrafuertes.
Old 16th January 2012, 05:37 PM   #23
Default The pics of the configurations
Sorry, the pics of the configurations are missing in the previous reply
here they are (or so I hope
Old 16th January 2012, 05:40 PM   #24
Hope in vain: mad:
"this time it surely go" (famous last words )
Old 16th January 2012, 09:03 PM   #25
gootee is offline gootee  United States
Why not like drawing "A", but with only one magnet on each side?
Old 17th January 2012, 01:55 AM   #26
rockguitardude is offline rockguitardude
Originally Posted by karellen View Post
Hope in vain: mad:
Scheme A will yield the best results.
Old 17th January 2012, 01:01 PM   #27
Thanks for helping
The problem using one magnet is that they want to be together and you need to glue them to the base (well, on previous atempts at last). If you stack them they remain in place without glue, due to the increased down force.
However its a configuration too good and simple to be fully discarded.
Pedro
Old 17th January 2012, 01:06 PM   #28
Thanks for helping
I think I will do a comparision between A and C
The C is intended for an epsilon layout, hence the increased width of the dual magnet configuration.
Hope this not shortcircuit the magnetic field...
Thank you again
Pedro
Old 18th January 2012, 01:43 PM   #29
Default Ready for testing
Ready for testing the two configurations; Epsilon and standard
rougly same size, same amount of magnets, same semi-skilled constructor...
Old 18th January 2012, 01:51 PM   #30
Default the epsilon first
I've just put together a test rig for an epsilon layout;
a little more than 2 Ohms.
the finish i'snt Apogee standard, I know, but it's just a test bench for that tecnology
and does it works?
yes
I'll try to write details later (it's lunch time!)
"La panza es primero"
Mini planar magnetic using neosHide this!Advertise here!
Planar magnetic with central tweeter? Few Planars & Exotics 103 22nd March 2016 02:17 PM
help designing a magnetic planar woofer baffleman Planars & Exotics 14 18th April 2014 05:01 PM
DIY Planar magnetic Hybride WrineX Planars & Exotics 71 9th August 2012 02:48 PM
Planar Magnetic Drivers - 8" rubicon Swap Meet 8 1st December 2010 08:22 PM
ESL vs Planar Magnetic Borat Planars & Exotics 40 8th September 2009 03:47 PM
Copyright ©1999-2017 diyAudio
