Planars & Exotics ESL's, planars, and alternative technologies
Antek Toroidal power transformer for Step-up, Measurements (part 1/2)
Old 25th September 2012, 01:54 AM   #41
bolserst is offline bolserst  United States
bolserst's Avatar
Originally Posted by geraldfryjr View Post
...you had stated that the Core Area of the Antek AN-0506 was about .7 square inches.
I was wondering if you could post the O.D. x I.D. x HT dimensions of the bare core in mm.
OD = 75 mm
ID = 39 mm
HT = 25mm
Old 25th September 2012, 05:56 AM   #42
geraldfryjr is online now geraldfryjr  United States
Thanks, bolserst!!!
Much appreciated !!!!
jer
Old 12th January 2013, 06:48 PM   #43
jeronimo83 is offline jeronimo83  Netherlands
Hello guys, hope you don't mind me interfering in this discussion. First post here.
I'm building a ESL for the first time and looking into transformer options, following this discussion closely. The ESL will be a wire stator. Membrane with 7500v high voltage bias supply.
I came across these toroids in my country by the company called Amplimo which produced (and possibly still produces) step up transformers for ESL:
380V transformator - Ringkerntrafo.nl
There is a PDF with specs that can be downloaded. Do you think I can use the 3 volt secondary winding to produce a step up of 1:127 with this toroid? If so, is there an alternative to connect the high voltage bias supply to instead of the missing center tap of this toroid? Or do I have to use 2 toroids per ESL for that? Furthermore, is it possible to make any assumption of the lowest frequency that will be possibly to produce with this transformer with a 2x80 watt amplifier?
I apologize for any stupid questions, I'm just a beginner and have almost no knowledge about electronics... yet
Old 13th January 2013, 03:57 AM   #44
bolserst's Avatar
If you drove the 3 volt secondary with an 80Watt amplifier, the lowest frequency you could expect the transformer to handle without running into core saturation problems is about 450Hz.
More details here:
http://www.diyaudio.com/forums/plana...ml#post2520512
If you want to use a transformer that does not have a center tap on its secondary, you can create a virtual CT using two 10Mohm resistors. Acoustat used this technique in their MK-141 interface.
Old 29th January 2013, 07:06 PM   #45
esltransformer is offline esltransformer  Georgia
Banned
I made myself a esl transformer for a electrical segmented esl on a large c-core. Stepup 1:125
Old 2nd February 2013, 04:38 PM   #46
bolserst's Avatar
That is a very nice response for a step-up ratio of 1:125.
Can you share how many primary turns were used and what the core size is?
Old 3rd February 2013, 02:23 PM   #47
Banned
Sure i can.
I use a c-core type: SU90B (600W/50Hz) with 54 windings primary and 6750 windings secondary.
I think impedance of a transformer is even more important then frequency response.
Here some more details from the transformer i made: impedance and saturation
Old 5th February 2013, 09:27 PM   #48
bolserst's Avatar
Sure i can.
I use a c-core type: SU90B (600W/50Hz) with 54 windings primary and 6750 windings secondary...Here some more details from the transformer i made: impedance and saturation.
I believe the SU90B core area is about 13.4cm^2.
If so, saturation starting at about 15Vrms is very impressive core capability with only 54 primary turns.
This would indicate flux density of about 18,000 Gauss = 1.8 Tesla if there was no resistance in the primary circuit.
Do you know what type of metal alloy the core is made from?
Did you have any external resistor in series with the primary?
What is the resistance of the primary winding?
Thanks for sharing the results of your transformer design.
Old 6th February 2013, 07:41 AM   #49
Banned
Indeed, 13.4cm^2 and at 20Vrms the core will be at 2T (then the core is almost saturated)
The core material i use is M0 (or HiB). The primary resistance is about 0.15 Ohm and normally i use a 1 Ohm serie resistance to protect my amplifier.
Antek Toroidal power transformer for Step-up, Measurements (part 1/2)Hide this!Advertise here!
Antek AS-4T430 measurements tomchr Tubes / Valves 8 24th February 2011 06:41 PM
Antek toroidal vs Edcor? Divad89 Tubes / Valves 12 9th February 2011 07:44 PM
FS:Antek Toroidal Transformer XEAGLEKEEPER Swap Meet 3 25th January 2011 10:18 PM
Where to buy step-down toroidal transformer with electrostatic shield? Kuro Power Supplies 3 15th June 2010 04:32 PM
Antek Toroidal Power Transformers wrenchone Tubes / Valves 1 10th August 2006 08:20 PM
Copyright ©1999-2017 diyAudio
