Planars & Exotics ESL's, planars, and alternative technologies
Cutting my own perforated panels
Old 17th November 2011, 02:45 AM   #1
joojoo1234 is offline joojoo1234  United States
Smile Cutting my own perforated panels
I have made the mistake of cutting my own perforated panels. Using metal shears. Getting some burrs that I will have to cut off and hammer down. Is this a problem and I need to order them cut?
Old 17th November 2011, 03:13 AM   #2
CharlieM is offline CharlieM  United States
CharlieM's Avatar
I suspect the shears distorted the metal along the cut edges. Hopefully the distortion is limited to the edges and can be hammered flat without stretching the metal. I would use a wooden mallet (not a metal hammer) to flatten the stators because you don't want to smash and "expand" the metal (which would create local buckling in the expanded areas). You will definitely want to grind off the sharp points along the cut edges to mitigate the tendency for coronal arcing.
Below is a photo of of a stator that had its edges ground smooth and then coated with polyurethane:
Old 17th November 2011, 07:42 AM   #3
Yes. I will deburr it. Not having a true shop is a true drag. Luckily I have most of the tools I need.
Old 17th November 2011, 07:43 AM   #4
I thought shearing with a pneumatic shear would be better then grinding... will use my grinder next to cut the 22 gauge.
Old 17th November 2011, 08:42 AM   #5
JAMESBOS is offline JAMESBOS  England
I use a pair of heavy solid metal scissors to cut my perforated steel. No problem, making planars you don't have to take the burrs off. In fact it helps to hold the sheet between the MDF sheets.
HENRY
Old 17th November 2011, 09:08 AM   #6
CharlieM's Avatar
I use a bandsaw with a metal cutting blade.
Old 28th November 2011, 08:34 PM   #7
Default I ordered a dual saw.
The cuts seem clean and I can use it for other things. Don't have a band saw.
Lack of sparks compared to grinding is nice. Can always return it...
Cutting my own perforated panelsHide this!Advertise here!
Diamond Perforated Aluminum for Stators jpancier Planars & Exotics 6 8th May 2010 08:24 PM
Perforated Grill dallas Multi-Way 4 12th May 2009 08:10 PM
What dimensions for perforated AL sheet? CarlyBoy Tubes / Valves 2 27th December 2007 12:21 AM
Laser or water cutting back panels? ak_47_boy Parts 6 10th September 2007 01:12 AM
degreasing perforated aluminum wrl Everything Else 26 30th July 2003 08:19 AM
Copyright ©1999-2017 diyAudio
