Planars & Exotics ESL's, planars, and alternative technologies
analysis epsilon
analysis epsilon
Old 20th June 2013, 03:20 PM   #241
john65b is offline john65b  United States
john65b's Avatar
If they are individual ribbons, kinda close...they touch/short, you may blow you amp...correct?
If they are ferrites, where can I source them??
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 20th June 2013, 04:19 PM   #242
tony jazz is offline tony jazz  Europe
tony jazz's Avatar
Ferrite magnets are at a cost of 040 each.
dimensions 75x16x11
Old 21st June 2013, 10:54 PM   #243
JAMESBOS is offline JAMESBOS  England
get your neos from china the best prices. That's where I got mine from and ferrites as well.
HENRY
Old 22nd June 2013, 08:03 PM   #244
john65b's Avatar
ebay? Can you forward a source of the 'net?
Old 2nd July 2013, 04:44 PM   #245
Atom666 is offline Atom666  Canada
Atom666's Avatar
Hi
I have a couple of questions after reading through the 25 pages.
What is the distance is between the magnets and the back of the diaphragm?
How are the magnets oriented on the perforated metal. Do they go N_S_N_S horizontally or are they just N_N_N_N (or for that matter S_S_S_S)?
Andrew
Old 3rd July 2013, 05:35 AM   #246
gootee is offline gootee  United States
Usually alternating vertical columns of N and S.
I measured the distance from the mylar to the steel, on my Magnepan MG-12s, a year or two ago, and also measured the magnetic field strength. I posted the results in one of the threads, here. So you should be able to find it with a search.
Maybe search for "mgnepan tesla gauss". I also seem to recall posting with the wrong units, once. So maybe searching for "tesla torr" would find it more quickly
Old 3rd July 2013, 07:55 AM   #247
Originally Posted by Atom666 View Post
Hi
Andrew
When I use ferrites the distance is 2 mm, and when I use neos the distance is 3 mm. When placing the magnets it is always NSNSNS etc. I have built the magnets both vertically and horizontally. I prefer the horizontal method overall, this gives better bass, I have found. I will probably experiment with tuning the diaphragm using springs. Should be interesting. I will have to experiment more as there are so many different parameters involved in building FRP I have found. Almost too many to get my head around. I only hope I am up to the task. Still we shall see, wish me luck.
HENRY
Old 8th March 2014, 06:37 AM   #248
ApogeeLover is offline ApogeeLover  United Kingdom
If anyone is still reading this thread and wants to understand how detailed the work involved in producing a good diy planar speaker, then have a good read of this site (The writer has made many many mistakes & discoveries along his path of enlightenment - avoid these considerations at your own cost of time/effort/money).
Do It Yourself - Ribbon Speakers - Project: La Folia magnetostatic by Mogens Gallardo
Planar speakers, when done correctly, don't just sound like 'speakers'...
...They sound Fabulous !!!
Enjoy.
Old 8th March 2014, 10:29 PM   #249
LIVE_EVIL is offline LIVE_EVIL  Malta
Are there any actually very detailed guides describing the build process in exact detail?
Old 9th March 2014, 11:03 AM   #250
thinkbad is offline thinkbad  Denmark
thinkbad's Avatar
Default Do It Yourself - Ribbon Speakers - Project: La Folia magnetostatic by Mogens Gallardo
Consider the article as a starting point, this is DIY after all.
You can improve this design in several areas, with even better sound to boot.
analysis epsilonHide this!Advertise here!
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 05:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 01:51 PM
noise analysis tenderland Tubes / Valves 5 29th March 2005 11:22 PM
cap analysis yldouright Parts 3 7th January 2005 01:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 07:13 AM
Copyright ©1999-2017 diyAudio
