Planars & Exotics ESL's, planars, and alternative technologies
analysis epsilon
analysis epsilon
Old 11th November 2011, 08:18 PM   #11
brian t is offline brian t  United Kingdom
brian t's Avatar
Old 12th November 2011, 08:52 AM   #12
arend-jan is offline arend-jan  Netherlands
R.I.P.
Amazing how a $10K speaker that looks high end on the outside, looks like it has been thrown together by someone in a shed from the inside :-)
my Quad ESL website.
Old 12th November 2011, 04:39 PM   #13
brian t's Avatar
yep my thoughts exactly would be disapointed if i had brought a new pair they wanted 2800 to fit new bass panels and upgrade xover plus shipping cost so its over 3k ouch! thats why i am having a go at repairing them myself.
Old 12th November 2011, 05:20 PM   #14
tyu is offline tyu  United States
But i say thay well sound great....I have had Apogee s An thay were ruff with the covers off .THe Bass could be tuned,An there is not much better..
To Me anyway...Is the tweeter moted at each end only,in free air ??
thanks
Old 12th November 2011, 08:27 PM   #15
brian t's Avatar
they are fixed at each end with support in the middle i have listened to these before and they are really transparant thats why i am going to the trouble of repairing them. in some respects they are the best speakers ive had .
Old 13th November 2011, 08:41 AM   #16
JAMESBOS is offline JAMESBOS  England
Hi Bryan T, You can get the foil from CPC 9 mm wide and 45 mtrs long for a few quid. I have used 100's of mtrs of this tape, and the glue is very good . It has lasted over 20 yrs without falling off. Best of luck.$10,000 for a pair of planar speakers, I'm glad I built my own. I have built over 25 full range planars and counting, still rebuilding my old designs, will it never end, such is life. I don't use rubber to fix my diaphragms, I use a wood frame and screws, which don't rot, and you can re-tension if need be. If the 9 mm is too wide you can cut the tape in half, I use scissors and have cut many many mtrs using this method.In fact I have to cut another 45 mtrs for my latest rebuild.
HENRY
Old 13th November 2011, 03:33 PM   #17
brian t's Avatar
henry, thanks for info will get some although it looks like the epsilon has thicker ali than the cpc tape, have removed panelClick the image to open in full size.
Old 13th November 2011, 03:39 PM   #18
brian t's Avatar
Click the image to open in full size. panel removed anyone got any ideas about what sort of rubber i can use for the suspension and glue,cheers brian
Old 13th November 2011, 04:27 PM   #19
Thanks For the Pix........Tweeter looks cool...Apogee never had the middel brace...Thay saged a littel.... Had a pr of the Duettes.....An Krell KSA250 my, my, set you hair on fire.....in a good way....latenight make some fear ed...bass to die for.....most fun ever..
How is it going... have cameup with the fix....
Old 13th November 2011, 06:16 PM   #20
brian t's Avatar
Click the image to open in full size. have done a temporary fix with double sided tape as i want to have a quick listen here a close up of ribbon for you
analysis epsilonHide this!Advertise here!
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 05:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 01:51 PM
noise analysis tenderland Tubes / Valves 5 29th March 2005 11:22 PM
cap analysis yldouright Parts 3 7th January 2005 01:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 07:13 AM
Copyright ©1999-2017 diyAudio
