Planars & Exotics ESL's, planars, and alternative technologies
analysis epsilon
analysis epsilon
Old 11th February 2012, 09:25 AM   #171
JarreYuri is offline JarreYuri  Sweden
One product that works is this:
The one who succeeded was the one who didn't know it was impossible.
Old 11th February 2012, 02:31 PM   #172
Rob Dingen is offline Rob Dingen  Netherlands
Hi Few
Just buy aluminium solder from Farnell Farnell Export
For aluminium foil it works perfect.
Rob
Old 11th February 2012, 04:24 PM   #173
Few is offline Few  United States
Thanks jer, that's the one I remembered. Unfortunately I don't think it's applicable to thin foils. I fear the mechanical scrubbing step would beat them up too much.
I'm a bit lost with the Farnell link but figured I'd make yet another attempt to find a promising source of solder for aluminum. KappAloy9 popped up but I haven't yet found a way to buy it.
Is that conventional Ersin multicore? I would have thought it would have the same problems with the oxide as other electronic solders. No?
Old 11th February 2012, 04:38 PM   #174
JAMESBOS is offline JAMESBOS  England
I never use solder just a penny washer, works every time and lasts for years.
HENRY
Old 11th February 2012, 05:04 PM   #175
The multicore solder works like a charm on foil!
Old 11th February 2012, 08:15 PM   #176
Good to know. I'll give it a try. I can't quite tell from the photo you posted which variety of Ersin solder you've had success with. My searching suggests there are multiple varieties. Does it say anything that distinguishes it on the label?
I may be doing something closer to the Analysis Epsilon approach than running a single conductor over the whole diaphragm. I'd rather be able to make solder connections at the top and bottom of each conductor than rely on tons of mechanical connections.
Thanks, all.
Few
Old 18th February 2012, 01:26 PM   #177
I haven't got it right here at the moment but at my workshop.
But from one of our companies here in Sweden You get this information...
The major important thing here is the fluss in the core that is ERSIN 362.
https://www.elfa.se/elfa3~se_sv/elfa...738|4|466938,;
Old 18th February 2012, 04:11 PM   #178
Default next project headphones 2 designs
The blue ones are my latest rebuilds, 7.1 Ohms. Then headphones 2 layouts see which is the best!
HENRY
Old 16th March 2012, 01:50 AM   #179
Default some more pics of rebuilds
A epsilon layout design using 5 separate layouts on 1 diaphragm, using 40 x 25 x 10 mm ferrites.
HENRY
Old 16th March 2012, 01:56 AM   #180
Default some more rebuilds using neos.
A new rebuild using 50 x 12.7 x 3 mm neos should be good for sensitivity etc.
HENRY
analysis epsilonHide this!Advertise here!
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 06:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 02:51 PM
noise analysis tenderland Tubes / Valves 5 30th March 2005 12:22 AM
cap analysis yldouright Parts 3 7th January 2005 02:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 08:13 AM
