Planars & Exotics ESL's, planars, and alternative technologies
analysis epsilon
analysis epsilon
Old 27th January 2012, 11:36 PM   #141
JAMESBOS is offline JAMESBOS  England
Default Latest rebuild, and my last redesign, I hope!
This is my latest rebuild, the first of many, using the epsilon layout which will be my last redesign.The blue one is the first of the pair, which weigh 5 kilos each, the other one is not quite finished. Just trying the pair together.My next rebuild will be the big one behind the blue one. Should be interesting in the bass!Then will build it's mate. No more gluing magnets. 2 more have come unstuck already. Not worth the hazel and doesn't improve sensitivity in fact it is less.
HENRY
Old 28th January 2012, 01:01 PM   #142
brian t is offline brian t  United Kingdom
brian t's Avatar
Henry you have been a busy boy! what glue have you been using for the magnets , have you tried double sided adhesive tape not as messy as glues.
Old 28th January 2012, 01:02 PM   #143
brian t's Avatar
Old 28th January 2012, 01:16 PM   #144
brian t's Avatar
Now have the speakers up and running its been a steep learning curve to source the correct suspension materials and satisfactory adhesives but if anyone else has the same problems at least its nice to know they are repairable and with the addition of the aluminium framework i believe an improvement over the factory build.Dont know how i listened to conventional speakers for so long these are a quantum leap up in performance its takes about 10 seconds to realise the difference,the lack of thermal compression is a real eye opener ,notes start and stop much better no overhang as with normal speakers. downsides? yes nothing is perfect you wont get chest thumping bass and one of the major short commings of panel speakers is loudness capability and as a previous owner of apogees i am pleased to confirm the epsilons can play as loud as you want due i suspect to being the only planar speaker i am aware of that has a bass panel suspension allowing the membrane to move futher and in a linear fashion.
Old 28th January 2012, 01:59 PM   #145
geraldfryjr is offline geraldfryjr  United States
Super Job, brian T !!!!
I am use that method when I go to tackle my Duette's.
When I first saw the Duette's (back in 1992),I wondered way they didn't incorporate a surround of some sort.
And now I sure wish they had as they diagphram profusely rattles now.
It makes no difference to me if it is kept original or not as they sound like crap right now.
But the tweeter ribbons are still in excellent shape though.
Super !!!
jer
Old 28th January 2012, 03:02 PM   #146
Won't be gluing anymore rebuilds redesigns not worth the hassle, every time you move them some more magnets come adrift. You only lose sensitivity with gaps, so no point.Well done with your rebuild looks nicer than original The epsilon layout with no gaps is I think my final rebuild. Only other thing is on the crossover side. Although I don't need any resistors as the diaphragm impedance is high enough with the layouts I am using. Looking forward to hearing my 4' x 2' redesign. using 23um mylar and quite a lot of 4.5 mm wide tape probably over 45 meters, so will have to join with penny washers! Just another 30 rebuilds to go.
HENRY
Old 28th January 2012, 03:13 PM   #147
brian t's Avatar
jerry if your not worried about returning your apogee duetta to original spec then yep they will be ideal for fitting a suspension to the bass diaphram, treble ribbon can stay as it is, let me know when your going to do it and will give you info on suspension.cheers
Old 28th January 2012, 03:24 PM   #148
Yep,I sure will !!!
If when I start in to them and mess up the original Diagphram I will have to build a new one.
I am not willing to spend the money having them replaced from a factory rep center when I can build or buy some thing better for much less.
This will also give me the chance to add an extra 2 or 3 more loops in magnetic field as well to bring the efficiency up a bit.
As long as they sound good they will look pretty much the same.
And If the original diagphrams get ruined then I only have the two options anyhow and either would be better than the way they are now!
jer
Old 29th January 2012, 08:40 AM   #149
Default EPSILON,UPDATE.
a few more pics of my latest rebuild and my next rebuild. The green is the epsilon layout which increases the sensitivity over the normal LA FOLLIA LAYOUT. Even though the diaphragm is much heavier the sensitivity is vastly improved, which after all is the end objective, is it not? Using all the magnet area in question. All these rebuilds hanging from the ceiling, will keep me busy and motivated. My first epsilon layout can be seen behind the blue one in the first picture.
HENRY
Old 29th January 2012, 11:51 PM   #150
Few is offline Few  United States
Brian: What did you end up using for suspension material and adhesives, if you don't mind me asking? The photos leave me with the impression Analysis used some sort of latex sheet for the suspension---just judging by the color and milky translucence of the material. Is that what you ended up using? If so, what thickness seems to do the job? And then there's the trick of getting all these polymers to stick to each other reliably... I can see why you've spent considerable time trying to work all that out.
analysis epsilonHide this!Advertise here!
epsilon lavardin amp help zerohead_ak47 Solid State 7 29th December 2008 05:02 PM
Midrange Analysis mbutzkies Multi-Way 4 25th May 2005 01:51 PM
noise analysis tenderland Tubes / Valves 5 29th March 2005 11:22 PM
cap analysis yldouright Parts 3 7th January 2005 01:45 AM
Need help in circuit analysis Fossil Tubes / Valves 6 23rd November 2004 07:13 AM
Copyright ©1999-2017 diyAudio
