Planars & Exotics ESL's, planars, and alternative technologies
Some More Questions On ELS Design
Old 1st November 2011, 04:30 PM   #11
geraldfryjr is offline geraldfryjr  United States
Isn't it possible too just use two tubes provided that they are the same size and with their feed hoses connected together in order to equalize the pressure between them?
jer
Old 2nd November 2011, 02:27 AM   #12
fperra is offline fperra  United States
Well, I finally got the two inner tubes glued together and no leaks. So I'm all set with that. Thursday I'll pick up the stator panels, work on de-burring them this weekend, and drop them off for powder coating on Monday. Soon, I'll start posting some pictures.
Old 2nd November 2011, 01:10 PM   #13
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
Nice! May I know how you glue the 2 inner tubes together?
Wachara C.
Old 2nd November 2011, 01:41 PM   #14
alexberg is offline alexberg
alexberg's Avatar
Wachara C.
That's easy - just put a piece of film inside the inner "inner" tube so inner walls would not glue together... and then stick inner "inner" one inside the outer "inner" one and press them together using vice... you gonna love English as a language
Sure, you need to degrease and make surface to which you apply adhesive roughed by sandpaper.
Adhesive is applied to outer surface of inner "inner" tube and inner surface of outer "inner" tube. Using two tubes you get two seals.
sic! Fingerprints are not good for adhesion. Rubber glue is the best
Almost forgot - seal shall be about inch wide
Old 2nd November 2011, 01:47 PM   #15
Wachara C.
I put a 3" piece of plastic tubing about the same diameter as the inner tube inside one end of the splice, roller the other end of the splice back onto itself, cleaned both sides, applied rubber contact cement, and unrolled the one side back onto the other. Let it dry for an hour and it holds pressure.
Old 2nd November 2011, 03:12 PM   #16
Very wise use of English indeed. Thanks for sharing.
Wachara C.
Old 2nd November 2011, 03:13 PM   #17
That sounds like very easy to do. Thanks for sharing.
Old 3rd November 2011, 02:49 PM   #18
How important is to have the holes of the front and rear stators aligned? Has anyone done any distortion measurements related this?
Old 3rd November 2011, 03:01 PM   #19
moray james is offline moray james  Canada
from a purely visual stand point it looks good (for the holes to line up) but from a performance point of view (and we ARE nit picking here) they ought to overlap. Bottom line dont worry about it and take what you get as it will be the least of your worries. Have fun and save your thinking energy for any real issues that may arise. Hope they won`t but hey it is all one big learning excercise. Best regards Moray James.
moray james
Old 3rd November 2011, 04:43 PM   #20
Thanks for the answer. I agree they will look better if alligned, but, logically thinking, it seems they would be more efficient if they overlapped.
Some More Questions On ELS DesignHide this!Advertise here!
Has anybody made an ELS headphone? chinsettawong Headphone Systems 450 4th February 2014 10:53 PM
ELS Construction Questions fperra Planars & Exotics 7 17th October 2011 01:01 AM
Metronome style design for multiple drivers, a number of design questions mountainhick Multi-Way 5 28th January 2010 03:31 AM
Curved ELS panels Johan_Ch Planars & Exotics 4 2nd November 2007 08:20 AM
Final 0.3 els systema Planars & Exotics 14 14th May 2006 04:10 PM
Copyright ©1999-2017 diyAudio
