Planars & Exotics ESL's, planars, and alternative technologies
Redesign ACOUSTAT III
Old 8th October 2011, 06:43 AM   #1
Williams Audio is offline Williams Audio  Jamaica
Default Redesign ACOUSTAT III
Hi all,
After spending a lot of time and money I finished the job
The total height now is 153 cm and xover was improved
It sounds different and better
Thanks to the nice fellows from the forum that helped me with he xover
Best regards,
Williams
williams audio
Old 8th October 2011, 06:51 AM   #2
some more pics of xover
williams audio
Old 8th October 2011, 06:43 PM   #3
hella356 is offline hella356  United States
Nice work! What frame material did you use? Did you maintain the stock panel angles or try other angles?
Old 8th October 2011, 07:02 PM   #4
thanks,
panels angels as they were
i reinforced the frame
the all thing is built in a modular way, can disconnect it from the base
the base frame is 1/2'' MDF and painted with a strong lacquer
williams
williams audio
Old 8th October 2011, 07:17 PM   #5
Did you retain the original frame & reinforce it, or build an entirely new frame? Where are the interfaces or Servos located? How would you describe the sound change? Do you have any rear and side photos? What grille material? Very striking look, sort of a modern take on the old Monitor 4 pedestal. Clean. Acoustat emblem looks right at home.
Sorry about the 20 Questions, but I'll be building new Monitor 8 frames so I'm very interested to hear insights on the frames.
Old 8th October 2011, 07:58 PM   #6
hi
feel free to ask what ever you want.
i will add some more pics.
the xover or the interface as you call it is behind the base.
the frame was totally disassembled and the panels taken out.
reused the MDF vertical poles and the red wood holders for the panels support.
i made new MDF frame parts for top and bottom and assembled all as a frame for the panels only.
the vertical base is 90 mm thick, connected to the panels frame with 5/16'' bolts, inside is empty , the panels wires passed tru it toward the xover that is located on the horizontal base.
the xover box is the original one, inside i did some changes because the capas were huge and did not fit inside.
williams
williams audio
Redesign ACOUSTAT IIIHide this!Advertise here!
Repair or redesign? Racket Scientist Solid State 3 30th August 2010 04:44 AM
Redesign classD amp. jazzy Class D 14 27th June 2010 06:42 PM
redesign amp need prorms Solid State 9 17th June 2006 08:35 AM
What to do , repair , replace or redesign. fortuosity Multi-Way 0 10th May 2006 01:23 AM
Redesign a factory speaker sazaks Multi-Way 11 14th November 2001 07:31 AM
Copyright ©1999-2017 diyAudio
