Planars & Exotics ESL's, planars, and alternative technologies
Active Crossover advice
Old 26th September 2011, 02:30 AM   #1
dochungwell is offline dochungwell  United States
Default Active Crossover advice
Hello All,
I am contemplating purchasing a Behringer CX2310 2-Way Stereo/3-Way Mono Frequency Crossover. I would like to use the crossover to control my 2 electrostatic speakers. The question is, can I use for example the right amp channel for the mids and highs, the left chanel for the same frequencies as the right, and the low frequencies can come from my pre-amp to the powered subs.
In other words, I believe with this configuration bi-amping is not necessary since I have a dedicated sub-out (using a powered sub), and the crossover will manage my two ESl's frequencies through the right and left channel.
I want to know if it is possible to hook up their system in this fashion, or has anyone configure their system similarly?
Thanks,
Doc
Doc
Old 26th September 2011, 03:29 AM   #2
CharlieLaub is offline CharlieLaub  United States
Originally Posted by dochungwell View Post
Hello All,
Thanks,
Doc
Doc
That's a very poor quality crossover IMHO. If you want a pro crossover, the DBX 223 is not much more expensive, and should serve you better in many ways. I have owned both.
-Charlie
Old 26th September 2011, 04:01 AM   #3
geraldfryjr is offline geraldfryjr  United States
Hello,Jerry!
Yes,That unit should work Nicely for your ESL's.
My friend Mavric had used that same unit when he had built his last spring.
How ever it is a Balanced in and out so you will have to get/or make the proper adapters.
You can only use that unit as a two-way crossover in stereo mode.
You can take the signal for the sub split off of the main unfilterd signal if you wish.
But, You my have more control over them if you hook them to the low side of the crossover unit.
jer
Old 26th September 2011, 11:54 AM   #4
Thanks Charlie, Jer
Charlie, I have heard they were not the best quality, however I am still shopping! so thanks for your opinion and I will continue to educate myself!
Jer, I always appreciate your comments. I was actually going to use the sub-out of the preamp and run it directly into the sub-in of the crossover...I just didnt want to complicate my question.
Thank,
Jerry
Old 26th September 2011, 03:11 PM   #5
I have read good reviews about the CX3400 and is a much more versital crossover as it does stereo 2 or 3 way.
For about $140 it's more money but it has alot more features, anything more than that you will be looking at the digital units.
Some have stated that the CX2310 is a little noisy,I don't have any experience with these units,But I have used other Behringer devices in the past without any issues and I didn't notice any noise problems with them.
jer
Old 27th September 2011, 12:11 AM   #6
bentoronto is offline bentoronto  Canada
I use the CX3400 with my Dayton-Wrights. Hardly nothing you can't make it do with some creative configuring. Seems as good quality sound as my other gear and vastly better than anybody's speakers, even my tri-amped mostly ESLs.
But, you can't trust the lousy silk-screened panel markings (or the inexpensive pots). So, be sure you verify settings and curves with a scope or mic.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio (and just posted data for a folded 17-foot pipe sub)
Old 28th September 2011, 01:59 AM   #7
Thanks Ben for you comments,
So after some research and Charlies suggestion and ordered the DBX223, and actually found it for 99.00 with free shipping!!!
Now for the last Item...for now anyway, is a Sub woofer.
I will post this as a question in this forum!
Thank you all for you comments and suggestions!
Jerry
Old 28th September 2011, 02:08 AM   #8
pcb121055 is offline pcb121055  United States
Wow! Sorry to jump in but where did you find such a deal? Partsexpress has them for 159. I need one too.
Old 28th September 2011, 02:13 AM   #9
a.wayne is offline a.wayne  United States
Sin Bin
So after some research and Charlies suggestion and ordered the DBX223, and actually found it for 99.00 with free shipping!!!Now for the last Item...for now anyway, is a Sub woofer.
Jerry
Thanks for not cluttering the thread by posting a link ...
Old 28th September 2011, 02:58 AM   #10
Sin Bin
Anyone here ever tried the ESP x-overs ...
Linkwitz-Riley Electronic Crossover
Active Crossover adviceHide this!Advertise here!
active crossover advice? neonleg Analog Line Level 19 25th October 2010 02:32 PM
Balanced active crossover advice zigzagflux Tubes / Valves 6 10th April 2007 06:07 PM
Need advice on this active crossover(please) ostie01 Multi-Way 0 13th February 2006 01:58 AM
Advice on active 6 dB crossover ostie01 Multi-Way 0 17th December 2005 11:45 PM
Active crossover advice Duck-Twacy Multi-Way 16 18th May 2003 06:07 PM
