Planars & Exotics ESL's, planars, and alternative technologies
Some interesting findings about Stax electrostatic stators
Old 2nd October 2011, 07:43 PM   #21
210 is offline 210  Germany
Hallo Wachara! If the spikes are conductive and work as controlled dischargers, you would need such material (maybe conductive plastic?). Maybe the powder coating will already make them conductive. Could you lend a multimeter from your friends (maybe one with 20megaohm range ore more) and measure the resistance (with cleaned measure pins) between the soldering point of the stator and some spike peaks ?
You know that's it: receive and transmit (Peter Gabriel
Old 3rd October 2011, 04:47 AM   #22
chinsettawong is offline chinsettawong  Thailand
chinsettawong's Avatar
I really don't think that they are conductive.
I'll try to see if I can measure anything with my multimeter.
Wachara C.
Old 3rd October 2011, 09:46 AM   #23
Probably the stator spikes just keep distance to prevent arcing/sparks and/or to prevent sticking of the diaphragm to the stators. But you, Wachara, can check for conductance to ensure.
Old 3rd October 2011, 03:23 PM   #24
bear is offline bear
expert in tautology
bear's Avatar
Can't really see what is there...
Take a magnifying glass, stick it flush to the lens on ur digital camera, put the camera in the closeup mode, hold the shutter halfway down to focus, then move the camera towards the object to focus - press shutter all the way... voila! Closeup really close!!
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 5th October 2011, 01:55 PM   #25
I've just checked the conductivity and it certainly is higher than my meter can measure. I confirm that there is a layer of powder coating on the stator.
Old 5th October 2011, 01:56 PM   #26
_-_-bear
I'll try to take a better picture to show you.
Old 6th October 2011, 08:23 AM   #27
Well, then you can try them at your speakers without this uncertanty. Btw. you forget to write till how many MHz you measured. Regards!
Old 10th October 2011, 10:36 AM   #28
arend-jan is offline arend-jan  Netherlands
R.I.P.
Why would that be relevant?
my Quad ESL website.
Old 11th October 2011, 03:51 PM   #29
bobnick is offline bobnick
I just don't see Stax using the spikes to bleed away the diaphragm charge at high deflection. I think it would be a clumsy way of limiting the displacement of the membrane under high drive and would give some peculiar audible effects - a long time constant on the diaphragm charging system would produce soft pauses in the music. In any case, even if it worked, I think the problems of reliable manufacture would outweigh any possible benefits.
I also do not believe that the spikes are there to prevent arcing. The stators are coated, probably with a high dielectric breakdown coating which would effectively prevent arcing. Also, Stax knows the absolute maximum drive voltages for all their amplifiers and has designed all their previous headphones without the need for such a system.
I also do not understand how a diaphragm could electrically 'stick' to a stator under any circumstances using the normal bias voltage, the negative compliance generated by the diaphragm charge would seem far too small to allow this. Can anyone explain a mechanism where this could happen?
I also have not been able to determine that squeeze damping of the fluid between the diaphragm and the stator would cause any sticking of the diaphragm to the stator given the size and shape of the perforations. In any case the hard limiting of the diaphragm deflection would already be causing very audible distortion.
Again, I still think that the spikes will introduce a form of soft limiting at high deflection. But, I also have no idea if this is the purpose of the spikes, I just think it a consequence.
Bob
Some interesting findings about Stax electrostatic statorsHide this!Advertise here!
Attenuation circuit findings Fe208e sigma adamt Full Range 0 22nd June 2010 03:20 AM
Interesting old Philco electrostatic tweeter peace brainerd Multi-Way 0 8th March 2010 11:56 PM
UltraLinear in toroidal parafeed, my findings. Shoog Tubes / Valves 2 4th February 2006 08:58 PM
Stators MrPin Planars & Exotics 10 12th January 2006 04:06 AM
Stax electrostatic headphones npdang Swap Meet 0 21st October 2004 08:33 AM
Copyright ©1999-2017 diyAudio
